Edelbrock 340 horsepower?
#1499957
09/11/13 02:19 AM
09/11/13 02:19 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I rebuilt my 340 about 3 months ago and got my car dynoed last week. First pull was best and it made 314 horsepower at 5500 rpm to the hubs & 343 ft/lbs torque Dyno guy said the AFR's were good so it was not needed to touch the carb My combo is a 340 bored .030 over Edelbrock heads out of the box Edelbrock RPM cam and RPM intake Stock cast crank 3.31 stroke, rods, rocker arms forged pistons 9.5 to 1 compression hydraulic lifters 650 cfm holley double pumper 1-5/8" headers to 3" exhaust with x pipe manual trans I figured with 10% drive train losses that my engine is making 345 horsepower to the flywheel which is 1 hp per cubic inch. I am no engine expert or anything and am happy with the motor as its really fun on the street. Just wondering if this is typical power output with this combo? thanks
Re: Edelbrock 340 horsepower?
[Re: RylisPro]
#1499958
09/11/13 02:25 AM
09/11/13 02:25 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
You'd have to post that camshafts specs for people to give and opinion of your numbers.
Why 3" exhaust with that combo? Seems a bit much.
[Re: autoxcuda]
#1499959
09/11/13 02:34 AM
09/11/13 02:34 AM
Posts: 2,432 NorCal
RylisPro
NorCal
My cam specs are http://www.edelbrock.com/automotive_new/mc/camshafts/locator.php?part_number=7177&submit=goCamshaft: Performer RPM Part #: #7177 Vehicle Type: CHRYSLER Engine Application: 318-340-360 V8 RPM Range: 1500-6500 DURATION AS ADVERTISED INTAKE: 308° EXHAUST: 318° DURATION @ .050 INTAKE: 234° EXHAUST: 244° LIFT @ CAM (Lobe) INTAKE: 0.325" EXHAUST: 0.34" LIFT @ VALVE INTAKE: 0.488" EXHAUST: 0.510" I got a great deal on a stainless 3 inch exhaust and could not pass it up. It sounds great and is actually not too loud with an X-pipe
[Re: RylisPro]
#1499960
09/11/13 02:47 AM
09/11/13 02:47 AM
Posts: 654 MN
astrobuf
MN
Your compression ratio is a bit low. Why did you drop it to 9.5:1? With the aluminum Edlebrock heads, 10.5:1 should have been easy.
For the CR you have, your power output is about as one would expect. Pretty conservative build from what I can tell. With just a bit more work, you could have been up closer to 400 HP and still very streetable.
Astrobuf
So, are you really a Rocket Scientist?
[Re: astrobuf]
#1499961
09/11/13 03:15 AM
09/11/13 03:15 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Closer to 20% loss for a stick 22% for an auto
I am truckless..
[Re: astrobuf]
#1499962
09/11/13 03:29 AM
09/11/13 03:29 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Aha! That might explain it. The engine has the same pistons from decades ago and I'm just working with what I got. Pistons are TRW L2385's and compression might actually be 8.5 to 1 ? I think my heads are 63 cc's
Next 340 that I build will have higher compression and that Ritter aluminum block
[Re: autoxcuda]
#1499964
09/11/13 11:20 AM
09/11/13 11:20 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I think on this Dynapack dyno that 10% is pretty accurate. I dynoed my S2000 on there and made 216hp +21 =237hp which is right at the factory rating. At 20% it would be at 270hp and no way a stock 4 banger would make that. I am still happy with 345hp and a healthy engine Next time I build, I know which areas to address Cam, compression etc...
[Re: WO23Coronet]
#1499969
09/11/13 04:13 PM
09/11/13 04:13 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Sounds about right for a 340 with what you have, are the heads ported or OOTB? One more thing, I thought you were going to do a Predator headed BB awhile back?
The heads are untouched and are out of the box
I still have all my Predator stuff but I'm getting rid of it because I'm going road racing and its overkill I want to do an all aluminum 340 with the Ritter aluminum block. If the aluminum small block came out years ago I would never have bought the Predator setup
