Fuel gauge problem #1499744
09/10/13 05:18 PM
09/10/13 05:18 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
I have a 67 Charger, the fuel gauge doesn't register fuel level.
I checked the gauge by grounding the wire at the sender, and it rises to full
I checked voltage at 5V
I ordered a new sender and still doesn't register.
Any thoughts on the problem would be appreciated
Re: Fuel gauge problem [Re: smmf] #1499745
09/10/13 05:49 PM
09/10/13 05:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you make sure the sender is grounded? There should be a metal strap that goes from the outlet on the sender to the metal fuel line on the car. It jumps the short rubber hose that joins the lines.See the clip 14-72-5
https://board.moparts.org/ubbthreads/upload2/4648384-untitled4.jpg
Re: Fuel gauge problem [Re: stumpy] #1499746
09/10/13 06:10 PM
09/10/13 06:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If the ground Stumpy mentions isn't the issue, then you have an open wire between the sender and the gauge. BTW, two hose clamps and a length of wire will substitute for the strap linked.
Don't be the exception.
Re: Fuel gauge problem [Re: Supercuda] #1499747
09/10/13 06:20 PM
09/10/13 06:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
He said when he grounded the sender wire the gauge worked so it's at the sender end.
Re: Fuel gauge problem [Re: stumpy] #1499748
09/10/13 06:24 PM
09/10/13 06:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You got me
Re: Fuel gauge problem [Re: stumpy] #1499749
09/10/13 09:46 PM
09/10/13 09:46 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
I actually had the sender out of the car to make sure I had it grounded. Both were aftermarket senders. Is there a ohm reading they should be?
Re: Fuel gauge problem [Re: smmf] #1499750
09/10/13 10:29 PM
09/10/13 10:29 PM
BDW Offline
BDW  Offline
Re: Fuel gauge problem [Re: smmf] #1499751
09/10/13 10:39 PM
09/10/13 10:39 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yes 73-10 ohms
I am truckless..
Re: Fuel gauge problem [Re: 340SHORTY] #1499752
09/10/13 11:08 PM
09/10/13 11:08 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
thanks
I checked them out and they seem good. I am at a loss on this. Everything checks out by themselves but as a unit I get no fuel level.
Re: Fuel gauge problem [Re: smmf] #1499753
09/10/13 11:19 PM
09/10/13 11:19 PM
BDW Offline
BDW  Offline
Make sure the float doesn't have a hole in it.
Re: Fuel gauge problem [Re: BDW] #1499754
09/10/13 11:37 PM
09/10/13 11:37 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
sending unit is out of the ca. I am manually raising the float. at the same time grounding it. I actually use a test light to make sure the unit is grounded.
Re: Fuel gauge problem [Re: smmf] #1499755
09/11/13 09:15 AM
09/11/13 09:15 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure the part inside the connector is contacting good.Ive seen them spread and or get corroded and not work.I always crimp them a but when I install the wire to the sender.I also run a ground from the battery to the sender to test them.Ive also seen where someone has tried to ground the sender on the hose instead of the nipple.I like to run a wire to the sender and ground it to the body.Its better than the factory clip.That and if the fuel line to the front isnt grounded the unit wont be grounded.Rocky
Chrysler Firepower
Re: Fuel gauge problem [Re: smmf] #1499756
09/11/13 09:18 AM
09/11/13 09:18 AM
Andrewh Offline
Andrewh  Offline
so, my end at the tank is a L shaped boot.
since it is a boot, there is a bit of rubber at the end before you hit metal.
even then, it is at only the sides.
is it possible, you don't have contact because of the rubber boot? the stud coming out is too short? or too thin to make contact with the sides?
try putting a bit of aluminum foil on the end of the stud coming.
enough that you feel pressure side to side putting it on. or pull the boot tight to one side.
Re: Fuel gauge problem [Re: Andrewh] #1499757
09/11/13 12:30 PM
09/11/13 12:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can just squeeze the boot lightly with a pair of pliers to tighten the connector.
Re: Fuel gauge problem [Re: stumpy] #1499758
09/11/13 10:27 PM
09/11/13 10:27 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
Thanks everyone for your help. Have tried everything suggested and more. Still the gauge and sender will not work together. I even borrowed an original sender still nothing.
But as stated earlier each piece functions individually but not together.
It has to be something stupidly simple
Re: Fuel gauge problem [Re: smmf] #1499759
09/11/13 11:04 PM
09/11/13 11:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Grounds as in electrical. Some sending units/ rheostats want to be "wet" IE: think fuel/vapors.
BUT be careful as a errant spark can send on to the local emergency room.
If the gauge and wiring are good which they appear to be from your posts, the problem is with the sending unit, grounds to it, or the connection to the unit. PERIOD!!! ground connections will send you to a mental institution, Nuff said!!! I suspect you think you have a good ground but the sending unit doesn't agree be careful
Re: Fuel gauge problem [Re: smmf] #1499760
09/11/13 11:16 PM
09/11/13 11:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
OK silly question, Out of the car, can you make the gauge work with the sending unit by grounding it, hooking it up and manually moving the float arm??
Re: Fuel gauge problem [Re: TJP] #1499761
09/11/13 11:21 PM
09/11/13 11:21 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
No I can not get the gauge with sender out of the car.
Re: Fuel gauge problem [Re: TJP] #1499762
09/11/13 11:28 PM
09/11/13 11:28 PM
Canada
smmf Offline OP
smmf  Offline OP
Canada
Thanks for your input. I feel the same as a bad ground. So I attached a ground wire from the sender to the frame plus I used a jumper cables from the battery to the sender.
I did not know about being wet.
I did get the gauge (with sender) to move just above empty and that was as far as it went. I am leaning towards the ground because the rheostat was a little warm, just can't think of a better way to ground it short of soldering it.
Plus I double checked the gauge by grounding it and it did go to full
Re: Fuel gauge problem [Re: smmf] #1499763
09/11/13 11:49 PM
09/11/13 11:49 PM
You might submerge it in a large container of water & with some jumper wires run 12V to the input nipple & ground the case & see how it acts submerged. Hold it at the same angle it would be in the tank
