Page 1 of 3 1 2 3
Cam and roller Lifter suggestions #1499509
09/10/13 11:15 AM
09/10/13 11:15 AM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
My 70 RR is almost finished. have a 440 engine topped with edelbrock heads and a six pack setup. I want to swap in a hyd roller cam. I want torque to be about 475-500. Any suggestions? Also what roller lifters do you guys recommend?
Re: Cam and roller Lifter suggestions [Re: relax383] #1499510
09/10/13 11:33 AM
09/10/13 11:33 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
With all the issues we have seen with hyd.roller lifters we quit using them.
Re: Cam and roller Lifter suggestions [Re: B G Racing] #1499511
09/10/13 11:47 AM
09/10/13 11:47 AM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Sounds like you need to do some research on hyd roller lifters. Because you must buy junk. They make a tool steel hyd roller lifter that's good to 7500 with no float.
Re: Cam and roller Lifter suggestions [Re: relax383] #1499512
09/10/13 02:58 PM
09/10/13 02:58 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Don't buy Comp hydraulic roller lifters. Mine lasted a few months. One by one they would collapse and rattle for a while then start working again. The last one to go just wouldn't pump back up. I pulled the lifters and took them apart. The metering plate under the pushrod cup had shattered on several lifters. A small piece of this plate would jam the valve open until it eventually worked it's way past the valve to the bottom of the lifter. The valve is another plate, unlike the lifters in the video Comp have on YouTube which show a ball valve. Comp Cams won't answer my emails.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Cam and roller Lifter suggestions [Re: Mick70RR] #1499513
09/10/13 05:18 PM
09/10/13 05:18 PM
SoCal
Brian Hafliger Offline
SoCal
We use Morel and have Comp grind our cams with the lobes WE pick.
The correct lobes/springs are a must for proper valvetrain control.
Brian
Brian Hafliger
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499514
09/10/13 08:16 PM
09/10/13 08:16 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
id like to see dyno proof of a big block mopar that can make power to 7500 with a HR.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Cam and roller Lifter suggestions [Re: relax383] #1499515
09/11/13 01:27 AM
09/11/13 01:27 AM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
So you guys are suggesting a custom grind?
Re: Cam and roller Lifter suggestions [Re: 68 HEMI GTS] #1499516
09/11/13 07:22 AM
09/11/13 07:22 AM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Ok let me start this way. If you are compentent, yes a hyd roller can go 7500 ask IMM. The problem with Moparts we have a bunch of people that think they know everything and I would not let them work on my lawn mower. That's the problem people listen to them and get bad info.
So take some time buy something else other than purple cams, spend some money and time yes a BBM will turn 7500 with hyd roller. Wait no it won't if you listen to most people and spend fours dollar on the valve train.
Sorry if a just butt hurt a lot of people, but truth is truth.
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499517
09/11/13 09:59 AM
09/11/13 09:59 AM
Saline, MI
E
efisixpack Offline
efisixpack  Offline
E
Saline, MI
Who makes hyd roller lifters out of tool steel? Last time I asked Morel they said they didn't. It was a year ago though. I'm running crane on a comp can with no issues. Unfortunately I do have other issues with the motor though, but not can/lifter related.
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499518
09/11/13 10:15 AM
09/11/13 10:15 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
doesn't hurt me a bit, you have know idea how much i know and i really don't care if you did. thats why i said i would like to see dyno proof. yea you might spin one 7500 with a missed shift, but i want to see it making power. BBM's are not SBF's or LS engines. you haven't showed or proved anything. you want me to ask someone who you think can do it. do you even build your own engines? its like the guy that says my buddy has has a buddy that has a car that will beat yours.
Re: Cam and roller Lifter suggestions [Re: 68 HEMI GTS] #1499519
09/11/13 11:07 AM
09/11/13 11:07 AM
gregsdart Offline
gregsdart  Offline
There are BBC motors running over 7,000, sold for fast brackets making 1,000 hp with a juice roller. The Mopar camp is behind on what is available and what works, in a lot of cases. Take a look at what can be done to lighten the load in the valvetrain, and that would be worth a lot of rpm over what the average guy tries to throw together to run a juice cam.
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499520
09/11/13 11:32 AM
09/11/13 11:32 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
How about the fact that we have used several different brands of aftermarket hyd.roller lifters and have customers bring in engines that were built elsewhere that have lifter issues.Buying junk doesn't even enter the picture since most all were top brand/dollar brands.Competence has nothing to do with it either.
The issues we have and have seen is lifters bleeding off or not pumping up because of metal shaving in the plungers,scores in the barrel,missing valves,springs,retainers and misaligned of the internal piston as well as other issues.Some of these can't be taken apart to even clean and check.
The issue is mostly poor quality control.We even go as far to spin the engines with out firing or use an accumulator to bring up oil pressure to pump collasped lifters after an engine set for a period of time.
I apologize for my earlier statement with out any facts to substantiate my remarks.I also apologize for being incompetent,uninformed as well as having no experience.I to your absolute knowledge in this matter and thank you for setting me straight.
Respectfully,
Bob
Re: Cam and roller Lifter suggestions [Re: B G Racing] #1499521
09/11/13 12:39 PM
09/11/13 12:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Respectfully,
Bob
Too funny Bob..............I think we`re related somehow.
Re: Cam and roller Lifter suggestions [Re: Thumperdart] #1499522
09/11/13 01:32 PM
09/11/13 01:32 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Ya your right I have no experince you win. I'm sure you figure your throw weights and use a spintron in your shop. I never have run more than 6.90 in quarter either so I have no drag racing or engine building experince.
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499523
09/11/13 01:48 PM
09/11/13 01:48 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Oh I forgot I need to bow down, I'm sorry legend Bob with all the hot cars that come out of that shop. I am really sorry I questioned anything you said. We all know Bob is god and knows everything and builds the fastest ten sec cars in the world lol!
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499524
09/11/13 01:52 PM
09/11/13 01:52 PM
Guitar Jones Offline
Hmm, so you're a paramedic and Bob is a what? I forget...
Re: Cam and roller Lifter suggestions [Re: Guitar Jones] #1499525
09/11/13 01:59 PM
09/11/13 01:59 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Other than I tune on some of the fastest grudge cars around guess nothing.
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499526
09/11/13 02:08 PM
09/11/13 02:08 PM
Washington
skrews Offline
skrews  Offline
Washington
Who's making good hyd roller lifters that go 7500 ? Seems like everyone I know, that goes down the hyd roller road has issues with them.
Re: Cam and roller Lifter suggestions [Re: relax383] #1499527
09/11/13 02:28 PM
09/11/13 02:28 PM
AndyF Online content
AndyF  Online Content
For a mild build with Edelbrock heads and a six pack intake manifold you should be fine with any off the shelf hyd roller setup. The guys at Hughes Engines can get you squared away or buy a Comp Cams setup right out of the catalog. Just don't go crazy with the duration or lift and you should be fine.
Re: Cam and roller Lifter suggestions [Re: skrews] #1499528
09/11/13 02:33 PM
09/11/13 02:33 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Mine Have been good to 6800+, hit 7200 a few times and feels like it could go higher. But If I'm shooting for 7500 my thoughts are why wouldn't you go with a lighter Solid Roller? i learned a lot about HR's from the mid 90's tuning on the Pro 5.0 type set ups where you had to run HR by class rules. Bullet was on the front line of that market and were always putting out new grinds to try back then.
Careful attention to valvetrain geometry and a very stable shaft foundation (my heads run a W2 style billet blocks instead of as-cast pedestals) I think helps a bit. And the Bullet desined HR lobes combined with the early (pre Chapter 11) Crane Lifters have worked very well for me is all I can say. I'm running long 11/32" stem x 2.25" intake valves which I think are lighter than the 2.14" x 3/8" stem mopars (the only BBM I can compare to from expereince).
But if Bob is saying there are issues I have no doubt there have been issues.
WIZE
In Car:
Page 1 of 3 1 2 3
