Two wire vintage tach installation help #1499332
09/09/13 09:33 PM
09/09/13 09:33 PM
Moncton, New Brunswick
hemidart1 Offline OP
I just picked up this vintage Dixco tach. It has only two wires. I was reading that one wire goes to power for light and the other to the negative side of the coil-and that it grounds on the mounting.
I have also read conflicting stuff about whether it will work with electronic ignition-is this true?
anyone have any experience installing these?
I love the look of the tach and would like to use it.
1967 Hemi GTX
1969 Chrysler 300
Re: Two wire vintage tach installation help [Re: hemidart1] #1499333
09/12/13 10:31 AM
09/12/13 10:31 AM
anyone?
1967 Hemi GTX
1969 Chrysler 300
Re: Two wire vintage tach installation help [Re: hemidart1] #1499334
09/12/13 12:16 PM
09/12/13 12:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I am puzzled as they normally have at least three wires. Have you taken the back off ??? A pic of the tach with the cup removed may help
Re: Two wire vintage tach installation help [Re: TJP] #1499335
09/12/13 02:12 PM
09/12/13 02:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Most require a sender.I have an old SW tach thats the 2 wire setup.It needs a sender to work.IIRC some of the senders also have a battery inside.Its been at least 30 years since Ive played with one.Rocky
Chrysler Firepower
Re: Two wire vintage tach installation help [Re: therocks] #1499336
09/12/13 02:18 PM
09/12/13 02:18 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
alot of tachs use two wires- no light in them.
tach goes between coil and points/ecu. maybe a in-out wires setup.
Re: Two wire vintage tach installation help [Re: 71_deputy] #1499337
09/12/13 02:30 PM
09/12/13 02:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try doing a Google search for the tach.There should be directions somewhere.Rocky
Chrysler Firepower
