Re: /6-318?
[Re: 76dodgeboy]
#1498726
09/09/13 05:33 PM
09/09/13 05:33 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I used my /6 10.5" flywheel and had it rebalanced for my 73 340.
BUT what size clutch is used on a /6 435 combo?
I am truckless..
Re: /6-318?
[Re: 76dodgeboy]
#1498728
09/09/13 05:46 PM
09/09/13 05:46 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Rock Auto shows the same flywheel for the 11" and 12" 143 tooth flywheel.. The 10.5 clutch uses the 130 tooth flywheel.
I am truckless..
Re: /6-318?
[Re: 76dodgeboy]
#1498730
09/09/13 06:31 PM
09/09/13 06:31 PM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Yes I did and the 1 you listed is the 130 tooth flywheel.. NOW the question to you is can the bell you have for the /6 435 take the 130 tooth or the 143 tooth flywheel? If your bell uses the 143 tooth flywheel and you use the 130 tooth flywheel arnt you going to have a problem with the starter not engaging because of the smaller diameter???
I am truckless..
