holley carb flooding after a pass #1497955
09/07/13 10:02 PM
09/07/13 10:02 PM
ont,canada
mopartuner Offline OP
ont,canada
After a run the car doesn't want to run it is flooded.is this from the vent tubes leeking into the carb?I checked the floats and are ok
410 pump gas solis flat tappet cam 10.95 so far
Re: holley carb flooding after a pass [Re: mopartuner] #1497956
09/07/13 10:28 PM
09/07/13 10:28 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I would pull the needle and seat out and see if any debris made it in and is sticking it. The rubber O ring can deteriorate and get lodged in there.
Re: holley carb flooding after a pass [Re: SpareParts] #1497957
09/08/13 06:21 AM
09/08/13 06:21 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I agree.. I've had that issue before. Also if you still have power valves in it check them out too...
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: holley carb flooding after a pass [Re: QTR MILR] #1497958
09/08/13 07:20 AM
09/08/13 07:20 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
A bad float will do this also .....sunken or leaking
Re: holley carb flooding after a pass [Re: mopartuner] #1497959
09/08/13 02:43 PM
09/08/13 02:43 PM
Aubrey, Texas
O
oldtimer5151 Offline
O
Aubrey, Texas
Make sure you have the two plastic anti pull over tubes in the metering plates.
