how do you guys keep your hood scoop from breaking? #1497486
09/07/13 02:45 AM
09/07/13 02:45 AM
california
hornetnut Offline OP
california
i have a hemi scoop on my car and at about 112 mph it really looks like its going to come apart.. i've seen alot of scoops with two bars in the opening to hold it together, what do you guys use to do it?
Re: pics of hood scoop fastners. [Re: hornetnut] #1497487
09/07/13 10:01 PM
09/07/13 10:01 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have 4 in the front and along the sides I have bolts with some stainless strapping that I put some holes in that my bolts go through. I have a strap on the scoop and under the hood.
Re: pics of hood scoop fastners. [Re: 70HemiGTX] #1497488
09/07/13 10:17 PM
09/07/13 10:17 PM
OHIO
THE GLASS MAN Offline
OHIO
Nice looking scoop, who made it?
Re: pics of hood scoop fastners. [Re: THE GLASS MAN] #1497489
09/07/13 10:19 PM
09/07/13 10:19 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
If I remember correctly it is an AAR piece.
Re: how do you guys keep your hood scoop from breaking? [Re: hornetnut] #1497490
09/07/13 10:53 PM
09/07/13 10:53 PM
Woodbridge NJ
E
ev2mopar Offline
ev2mopar  Offline
E
Woodbridge NJ
I had a Hemi hoodscoop in my street car and had the same issue.
I found aluminum tubing, polished it in my drill press, and cut it to 4 sections.
Each section of tube was secured by 4 long stainless screws and locknuts, from the topside of the scoop and the nuts on the inner hood side.
It wasn't the prettiest, bit it definently kept the scoop from wanting to (or at least looking like it was) blow off.
Re: how do you guys keep your hood scoop from breaking? [Re: hornetnut] #1497491
09/07/13 11:01 PM
09/07/13 11:01 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
So who made your scoop .... With no t-nuts in the opening of said scoop ? ...I probably made 500 of those scoops and put at least 2 or as many as 6 supports in each scoop.
Re: how do you guys keep your hood scoop from breaking? [Re: dOc !] #1497492
09/07/13 11:15 PM
09/07/13 11:15 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I also put a piece of 1/8" aluminum right angle stock behind the front edge of the hood and fastened the front lower lip of the hood to it. That really cut down on the flexing. I actually have cracks in the front point of the hood from before I put the brace in.
Re: how do you guys keep your hood scoop from breaking? [Re: 70HemiGTX] #1497493
09/08/13 12:19 AM
09/08/13 12:19 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have a race weight lift off VFN that I put 3 aluminum tubes in as pictured above . I have fixed the small paint cracks twice in 35 years. The first time was soon after I got the hood and ran it down the quarter mile without the front bracing, as you stated, the scoop got very big. Once you put in the braces,the front of the scoop won't flex but the rest of the fiberglass will. If you want a fiberglass hood and drive the car you will get cracks , the same as corvettes and after market hoods are not even close in quality as the corvette.
Re: how do you guys keep your hood scoop from breaking? [Re: dOc !] #1497494
09/08/13 02:19 AM
09/08/13 02:19 AM
california
california
i bought it off of ebay, including shipping it was only 75 bucks.. i was really impressed with the quality of it, it is fiberglass and has a top coat that was nice enough that i didnt even paint it.
Re: how do you guys keep your hood scoop from breaking? [Re: hornetnut] #1497495
09/08/13 02:49 AM
09/08/13 02:49 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If your having problems at about 112 MPH, try only driveing at about 111 MPH ...
I am truckless..
Re: how do you guys keep your hood scoop from breaking? [Re: 340SHORTY] #1497496
09/08/13 02:56 AM
09/08/13 02:56 AM
They get really bigger above 125 MPH
Re: how do you guys keep your hood scoop from breaking? [Re: Cab_Burge] #1497497
09/08/13 03:04 AM
09/08/13 03:04 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The RO/WO scoop on my shorty would start lifting around 75 till I put the 2 screws in it...
I am truckless..
Re: how do you guys keep your hood scoop from breaking? [Re: 340SHORTY] #1497498
09/08/13 03:09 AM
09/08/13 03:09 AM
california
california
If your having problems at about 112 MPH, try only driving at about 111 MPH ...
got a good laugh out of that one!! last time out it went 120... going again tomorrow with a 75 shot on it, so looking for a lil more, just went out and fabbed a couple of tubes and bolts that will hold it in place..
