transmission pan gasket leak??? #149742
11/12/08 02:45 PM
11/12/08 02:45 PM
Southeastern Ohio
1st_charger Offline OP
Southeastern Ohio
Ok I've been fighting a trans pan gasket leak and looking for some options! Right now I have a cork gasket and it seams to leak alittle if I just take the car for a short drive say 5 miles total. If I'm out for longer I dont seam to notice it untill the car has set for a few days! Its not a big leak but I'm tired of cleaning up the puddle under the car! is there a better gasket to use or maybe a little silicone on the cork?? I built the trans about 800 miles ago and the cars put up for winter Just wanting to get something worked out before next spring!
Ive also retorqued the pan bolts but the leak is still there!
Re: transmission pan gasket leak??? [Re: 1st_charger] #149743
11/12/08 03:03 PM
11/12/08 03:03 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Are you sure it is the pan gasket? Oil leaks down and if it is something like a the front pump, dipstick tube, or shift shaft seal it will get the gasket wet and make it look like it is from there. Mined was from shift shaft seal and I just replaced mine about a month ago
I also pulled the pan off mine so I can remark the level for the dipstick since it was a aftermarket unit. I reused the old pan gasket and it sealed up fine.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: transmission pan gasket leak??? [Re: 1st_charger] #149744
11/12/08 03:05 PM
11/12/08 03:05 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Is the pan rail warped? Remove the pan and lay it on a flat surface. May be time for a new pan.
Re: transmission pan gasket leak??? [Re: Pntastar69] #149745
11/12/08 03:13 PM
11/12/08 03:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that and loose the cork gasket , they are crap .
the delser has a hard gasket with o rings that is supposed to work well
Re: transmission pan gasket leak??? [Re: JohnRR] #149746
11/12/08 03:56 PM
11/12/08 03:56 PM
mopar has a pastic frame, o-ringed tranny pan gasket that wont squish out. works like a charm. call the mopar parts department and ask for it
Re: transmission pan gasket leak??? #149747
11/12/08 04:20 PM
11/12/08 04:20 PM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
Worth the little extra.
Re: transmission pan gasket leak??? [Re: copper67440] #149748
11/12/08 04:28 PM
11/12/08 04:28 PM
MP# 2464324AC (727)
Re: transmission pan gasket leak??? [Re: RapidRobert] #149749
11/12/08 04:48 PM
11/12/08 04:48 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Yes that new type gasket is trick ... but way overkill IMO.
MOST leakage I have ever seen is from either a bent or warped pan-rail or way WAY over-tightening of the pan-bolts.
Re: transmission pan gasket leak??? [Re: dOc !] #149750
11/12/08 05:05 PM
11/12/08 05:05 PM
scratchnfotraction Offline
clean it good with brake clean
dry with air,throw a handful of baby powder around the shift shaft seals,fill tube,n-safty switch,speedo plug,tail shaft gasket on top of the pan gasket
let sit over night,look see where its leaking or seeping from
clean and fix
x3 on the dealer hard pan gasket,works very good,have reused mine a couple times already
dont over tighten the pan bolts,they will strip out before the gasket sqeezes out...DAMHIK
best way I have found to spot any leak on a tranny
Re: transmission pan gasket leak??? [Re: HealthServices] #149751
11/12/08 06:54 PM
11/12/08 06:54 PM
BDW Offline
BDW  Offline
Totally agree, I replaced my gasket 3 times, before I figured out it was leaking from 4 other places!
Re: transmission pan gasket leak??? [Re: scratchnfotraction] #149752
11/12/08 11:15 PM
11/12/08 11:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
clean and fix
Hopefully it's not the low /reverse shaft o-ring seal .
if it is good time for a rebuild. Another problem in the same area is the tailshaft snap ring gasket. Do as mentioned above and you'll have the answer
Re: transmission pan gasket leak??? [Re: dOc !] #149753
11/13/08 10:03 AM
11/13/08 10:03 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
quote]
I can't believe you said that.For a $10.00 gasket anyone would be a fool not to use it instead of the old cork or rubber.
Re: transmission pan gasket leak??? [Re: 62maxwgn] #149754
11/13/08 10:12 AM
11/13/08 10:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I can Bill , the doc is so tight he squeaks when he walks , he would rather use a cork gasket and 5 bucks worth of RTV than buy a REUSABLE gasket
of course now I'll get harassing emails and other barbs thrown at me for stating the OBVIOUS .
Re: transmission pan gasket leak??? [Re: JohnRR] #149755
11/13/08 10:31 AM
11/13/08 10:31 AM
Ive reused that reusable gasket twice now (with NO RTV) so Im ahead of the game. Oh ya, it didnt leak or squish out either and that makes it worth every cent I paid
Re: transmission pan gasket leak??? #149756
11/13/08 10:43 AM
11/13/08 10:43 AM
We have one day of good weather so I have to decide today, cork or the good one which is going to cost me $21.53 at the dealer. I'll have to try the baby powder trick as I've been fooled several times on where they're leaking.
Re: transmission pan gasket leak??? [Re: RapidRobert] #149757
11/13/08 11:35 AM
11/13/08 11:35 AM
I would check that stealer
mine was 12.58$,used several this yr on other peoples rides I was a tunin up
Re: transmission pan gasket leak??? [Re: scratchnfotraction] #149758
11/13/08 11:39 AM
11/13/08 11:39 AM
yeah I better call them again & the other dealer in Lincoln. That does sound pretty steep.
Re: transmission pan gasket leak??? [Re: RapidRobert] #149759
11/13/08 12:03 PM
11/13/08 12:03 PM
I believe I paid $20 something for mine but my local dealer is a ripoff
Re: transmission pan gasket leak??? [Re: RapidRobert] #149760
11/13/08 12:04 PM
11/13/08 12:04 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Like I said,ten bucks from my dealer,but he likes me!
Re: transmission pan gasket leak??? [Re: 62maxwgn] #149761
11/13/08 12:35 PM
11/13/08 12:35 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
On my car the problem was the collecter flange for my TTI headers is close to the corner of the 727 pan gasket on the pass side. I also used the new MP gasket and now...no more gasket leaks. Spend a few bucks extra and do it rite.
