Re: transmission pan gasket leak???
[Re: 1st_charger]
#149743
11/12/08 03:03 PM
11/12/08 03:03 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Are you sure it is the pan gasket? Oil leaks down and if it is something like a the front pump, dipstick tube, or shift shaft seal it will get the gasket wet and make it look like it is from there. Mined was from shift shaft seal and I just replaced mine about a month ago I also pulled the pan off mine so I can remark the level for the dipstick since it was a aftermarket unit. I reused the old pan gasket and it sealed up fine.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Pntastar69]
#149745
11/12/08 03:13 PM
11/12/08 03:13 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Is the pan rail warped? Remove the pan and lay it on a flat surface. May be time for a new pan.
that and loose the cork gasket , they are crap .
the delser has a hard gasket with o rings that is supposed to work well
[Re: JohnRR]
#149746
11/12/08 03:56 PM
11/12/08 03:56 PM
mopar has a pastic frame, o-ringed tranny pan gasket that wont squish out. works like a charm. call the mopar parts department and ask for it
[Re: dOc !]
#149750
11/12/08 05:05 PM
11/12/08 05:05 PM
Posts: 15,487 Florida
scratchnfotraction
clean it good with brake clean dry with air,throw a handful of baby powder around the shift shaft seals,fill tube,n-safty switch,speedo plug,tail shaft gasket on top of the pan gasket let sit over night,look see where its leaking or seeping from clean and fix x3 on the dealer hard pan gasket,works very good,have reused mine a couple times already dont over tighten the pan bolts,they will strip out before the gasket sqeezes out...DAMHIK best way I have found to spot any leak on a tranny
[Re: HealthServices]
#149751
11/12/08 06:54 PM
11/12/08 06:54 PM
Posts: 4,752 Florida
BDW
Totally agree, I replaced my gasket 3 times, before I figured out it was leaking from 4 other places!
[Re: scratchnfotraction]
#149752
11/12/08 11:15 PM
11/12/08 11:15 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
clean and fix
Hopefully it's not the low /reverse shaft o-ring seal .
if it is good time for a rebuild. Another problem in the same area is the tailshaft snap ring gasket. Do as mentioned above and you'll have the answer
[Re: dOc !]
#149753
11/13/08 10:03 AM
11/13/08 10:03 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Yes that new type gasket is trick ... but way overkill IMO.
quote]
I can't believe you said that.For a $10.00 gasket anyone would be a fool not to use it instead of the old cork or rubber.
[Re: 62maxwgn]
#149754
11/13/08 10:12 AM
11/13/08 10:12 AM
JohnRR
I can Bill , the doc is so tight he squeaks when he walks , he would rather use a cork gasket and 5 bucks worth of RTV than buy a REUSABLE gasket
of course now I'll get harassing emails and other barbs thrown at me for stating the OBVIOUS .
[Re: JohnRR]
#149755
11/13/08 10:31 AM
11/13/08 10:31 AM
Ive reused that reusable gasket twice now (with NO RTV) so Im ahead of the game. Oh ya, it didnt leak or squish out either and that makes it worth every cent I paid
#149756
11/13/08 10:43 AM
11/13/08 10:43 AM
RapidRobert
We have one day of good weather so I have to decide today, cork or the good one which is going to cost me $21.53 at the dealer. I'll have to try the baby powder trick as I've been fooled several times on where they're leaking.
#149758
11/13/08 11:39 AM
11/13/08 11:39 AM
RapidRobert
yeah I better call them again & the other dealer in Lincoln. That does sound pretty steep.
[Re: RapidRobert]
#149759
11/13/08 12:03 PM
11/13/08 12:03 PM
I believe I paid $20 something for mine but my local dealer is a ripoff
