Re: did my alignment guy get it wrong?
[Re: mcmopars]
#1497141
09/06/13 02:01 PM
09/06/13 02:01 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
What kind of car?Bias or radial tires.The 2.5 camber is a lot.Bias and radial tires are 2 different specs.Rocky
Chrysler Firepower
[Re: ahy]
#1497145
09/06/13 02:24 PM
09/06/13 02:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I like to give my car as much positive caster as I can as it handles better like that. And caster has nothing to do with tire wear. But to much makes the wheel harder to turn on manual steering. I believe stock specs for chamber are 0 to .5 but I would have to look up the specs to be sure. Camber can cause tire wear if to far out of specs. But I have not seen a car with camber set to factory specs where you could actually see the tire out to much at the top. Ron
