which epoxy? JB weld or ?
#1497074
09/06/13 12:02 PM
09/06/13 12:02 PM
RapidRobert
oil pickup mods. What do you recommend I use? Thank you for your time.
Re: which epoxy? JB weld or ?
[Re: RapidRobert]
#1497076
09/06/13 06:24 PM
09/06/13 06:24 PM
Posts: 654 MN
astrobuf
MN
Do not leave epoxy exposed to oil, it will eventually swell and dislodge/debond. Why would you want to use an epoxy with a vibrating oil pump.
Astrobuf
So, are you really a Rocket Scientist?
[Re: ek3]
#1497078
09/09/13 11:43 AM
09/09/13 11:43 AM
RapidRobert
OK, I will have it gas welded
[Re: BB65Barracuda]
#1497087
09/10/13 10:16 AM
09/10/13 10:16 AM
Challenger 1
Cincinnati, Ohio
Astrobuf
Vibrating oil pump? It would seem If you have harmonics that severe his pick up would be the least of his worries.
An oil pump is a bit like a tuning fork. The pickup is flexible and has mass on the end. Take a hammer and bang on an oil pump, you'll see the pickup wiggle, especially at its resonant frequency. The engine firing pattern does the hammering.
Astrobuf
Hmmm! You sure sound convincing.
I have broke off the entire oil pump from a BB chevy more than once from tire shake. They make a brace to keep it from happening, I fixed it for good by going with a belt driven external pump.
When you start making power you learn about these things.
[Re: dogdays]
#1497091
09/10/13 01:30 PM
09/10/13 01:30 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Sorry I'm just a lowly Electrical Engineer. Your intellect is obviously far superior to my own. I bow down before you! I'm pretty sure most all of the manufacturers support or have a distance they keep the pickup of the bottom of the pan so it stays submerged in the oil. Im pretty sure it is not recommended to set the pickup directly on the floor of the oil pan.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: BB65Barracuda]
#1497093
09/10/13 02:31 PM
09/10/13 02:31 PM
Posts: 4,744 Florida
BDW
Don't you dare apologize, everyone knows mechanical engineers are the ones who couldn't cut it in the EE dept.
Bazinga!
