TTI X pipe install - having issues #1496757
09/05/13 09:29 PM
09/05/13 09:29 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Just test fitting the new x pipe on the Dart. Car has a 383 with TTI headers, x pipe is 3". If I slip the pass side on the driver's side is a good 4-5 inches wide left (to the outside of the car) of the header collector. However, the x is nice and centered with the drive shaft right down the middle.
How much should I expect to modify this?? Given the marketing I thought the slip elbows allowed for enough adjustment to not have to re-engineer the system.
I see the 'L' and 'R' markings. I assume standing in front of the car 'R' is driver's side.
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496758
09/05/13 09:41 PM
09/05/13 09:41 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
""I see the 'L' and 'R' markings. I assume standing in front of the car 'R' is driver's side
I "ASSUME" you are wrong..
I am truckless..
Re: TTI X pipe install - having issues [Re: 340SHORTY] #1496759
09/05/13 10:15 PM
09/05/13 10:15 PM
central P.A.
HEMIDOG 70 Online content
HEMIDOG 70  Online Content
central P.A.
Left and right are seen as from sitting in the drivers seat.
Re: TTI X pipe install - having issues [Re: 340SHORTY] #1496760
09/05/13 10:16 PM
09/05/13 10:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You ASSuME ??? ...
Left is ALWAYS the drivers side ...
Re: TTI X pipe install - having issues [Re: JohnRR] #1496761
09/05/13 10:25 PM
09/05/13 10:25 PM
Canton, Ohio
Canton, Ohio
Thanks (and embarrassing) now that I think about it. I'll flip things around and see if I have better luck.
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496762
09/05/13 10:56 PM
09/05/13 10:56 PM
Canton, Ohio
Canton, Ohio
Well, right or left, same issue, not even close to lining up with the collectors.
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496763
09/05/13 11:02 PM
09/05/13 11:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
That X is probally a generic fit part.. I imagine you will need to do some and ...
I am truckless..
Re: TTI X pipe install - having issues [Re: 340SHORTY] #1496764
09/06/13 12:08 AM
09/06/13 12:08 AM
MN
astrobuf Offline
astrobuf  Offline
MN
I think you paid enough for the TTI exhaust that it should fit. Have you contacted TTI Tech Service? They should be best able to sort this out. You may have the wrong pieces?
AStrobuf
So, are you really a Rocket Scientist?
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496765
09/06/13 01:06 AM
09/06/13 01:06 AM
Idaho
boomerodell Online content
boomerodell  Online Content
Idaho
I just installed a 3" x-pipe system on my 73 cuda. 383 with tti headers and dynomax mufflers. Had some similar issues. I just hosed all the slip joints down with white lithium grease and it helped ALOT! Let all those joints move in and out and twist around. At first I was ready to give up and take it to a muffler shop and have them modify it. All the pieces have the part numbers on them so I would double check them with the install sheet.
Re: TTI X pipe install - having issues [Re: boomerodell] #1496766
09/06/13 07:29 AM
09/06/13 07:29 AM
Canton, Ohio
Canton, Ohio
I'll look at it again this weekend. The joints are covered with never-seize and everything moves freely. The system is wide by 4-5 inches.
Re: TTI X pipe install - having issues [Re: boomerodell] #1496767
09/06/13 09:06 AM
09/06/13 09:06 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes the pipes have numbers that you match up on each end, there's no guessing what goes where and then it will fit correctly. They are very small and a lot guys don't know their there. Match the same number on each end and you will know for sure if you have it together right.
Re: TTI X pipe install - having issues [Re: Challenger 1] #1496768
09/06/13 01:50 PM
09/06/13 01:50 PM
Canton, Ohio
Canton, Ohio
Yeah, I know the numbers are there with the R and L designations. I'll triple check.
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496769
09/06/13 04:47 PM
09/06/13 04:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If the front sections (between collectors & X) have different lengths before & after the bend, turn them around. Putting the shorter length into the X narrows them, longer length widens them.
Some parts stores carry short lengths of slip-fit 3" exhaust tubing, which you can use to make the system wider.
Not all header makers' collectors are in the same position, and TTI probably made their X-system to fit their headers.
Re: TTI X pipe install - having issues [Re: topside] #1496770
09/06/13 05:11 PM
09/06/13 05:11 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Re: TTI X pipe install - having issues [Re: Dcuda69] #1496771
09/06/13 06:45 PM
09/06/13 06:45 PM
Canton, Ohio
Canton, Ohio
I'm going to try to get into the garage tonight. The X pipe needs to be more narrow, not wider.
Yes, 383 with TTI headers...
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496772
09/06/13 09:47 PM
09/06/13 09:47 PM
Canton, Ohio
Canton, Ohio
The x pipe is simply too wide. XA30MP is the P/N which matches the sheet for 67-76 A body. I've got the elbows on the proper side per the markings. They cannot be flipped as they are flared on one side.
Guess I need to decide if I want to send this stuff back or mod it. I bought it because I was hoping it would be relatively easy to install. Not too excited about cutting it all up. I could have done that with a custom made system for a lot less money.
I bought through Mancini. I wonder if they can help out in any way.
This car.....
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496773
09/07/13 11:14 AM
09/07/13 11:14 AM
Ohio
billohio Offline
billohio  Offline
Ohio
I would call tti. I put 3 inch on a b body with a hemi and had no trouble at the x but did above axle. One side had to be trimmed. They were helpful
Re: TTI X pipe install - having issues [Re: billohio] #1496774
09/07/13 11:42 AM
09/07/13 11:42 AM
BDW Offline
BDW  Offline
I agree, call TTI, my system would not fit. Turns out there was a wrong pipe in the set.
Once I got the correct piece it fits like a glove.
Send them some pics.
Re: TTI X pipe install - having issues [Re: BDW] #1496775
09/07/13 01:29 PM
09/07/13 01:29 PM
Canton, Ohio
Canton, Ohio
I'll get some pics and get a hold of them on Monday.
Re: TTI X pipe install - having issues [Re: Crazy68Dart] #1496776
09/09/13 06:41 PM
09/09/13 06:41 PM
Canton, Ohio
Canton, Ohio
Talked to TTI. No real help. Since these are 2" headers on a low deck he claims that is attributing to the problem. I bought these headers knowing they were big so I didn't have to buy things twice when I build the larger CID stroker.
Anyway, he also said the slip elbows need to be cut down on occasion.
So, I am back to modifying things, or sending them back. Considering the restocking fee and shipping I need to think this through. Maybe someone local can make me some proper slip elbows. I'd rather not have to cut the heck out of everything.
