over drive trans #1496696
09/05/13 05:34 PM
09/05/13 05:34 PM
california u.s.a.
racecar43 Offline OP
california u.s.a.
Any input on the easy and best overdrive trans to use in an early abody small block?..
Re: over drive trans [Re: racecar43] #1496697
09/05/13 05:53 PM
09/05/13 05:53 PM
dogdays Offline
dogdays  Offline
A833OD will be the easiest. It fits without welding.
It is not the best, although the lighter A-body weight removes some of the problems of the huge ratio drops.
Probably the R154 Supra Turbo 5-speed is next, I believe it doesn't require modifying the torsion bar crossover, could be wrong. But the shifter is in a different place, IIRC.
Problem to me is that on a linear scale, "easy" is at one end of the scale and "best" is as far away as it can be. So while a modern 5 or 6 speed built to handle mountains of torque is best, it is also the most difficult to actually install in the car. And the A833OD is easiest but its large gear splits make it also the worst.
Get the picture?
R.
Re: over drive trans [Re: racecar43] #1496698
09/05/13 06:37 PM
09/05/13 06:37 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Manual or automatic?
- Stu Harmon
Re: over drive trans [Re: feets] #1496699
09/05/13 07:22 PM
09/05/13 07:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
lol, huge ratio drops, ha ha.
I suppose if you were running a 4 cylinder in a D350 yeah it'd be a problem. But one wonders if you have actually ever driven one.
I suggest you look at the ratios of three speed manuals of the same era and compare them to the A833OD, pretty close or "worse" and no one cries about huge ratio drops there.
http://www.moparts.org/Tech/Archive/clutch/17.html
I have a 65 Cuda, early A body, I am fitting an A833OD into. It has a 318 and a 3.55 rear gear.
Don't be the exception.
Re: over drive trans [Re: Supercuda] #1496700
09/06/13 03:01 AM
09/06/13 03:01 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
65 is not a direct bolt in it will take a 66 drive shaft that uses a standard U joint not a ball and trunnion style If I remember correctly I had to notch the X member to clear the linkage
Thats been way too long ago and may have been when we put a 440 in a 65 Dart
30 plus ago
Re: over drive trans [Re: BulletBob] #1496701
09/06/13 10:19 AM
09/06/13 10:19 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Easier to do this swap and it was to put one into my 87 Diplomat. I am intimately familiar with what needs doing when converting over. I usually spend whatever time is needed to get the parts I need at a low cost. Took me two years to gather up the stuff to swap into the Diplomat, but it cost me under $500 to go from auto to stick. Cuda is on course for about the same cost.
Re: over drive trans [Re: Supercuda] #1496702
09/06/13 03:09 PM
09/06/13 03:09 PM
dogdays Offline
dogdays  Offline
My first new car was a 1972 Chevy Nova with a 350 and 3-speed on the floor. It had those huge drops I am talking about, so yes I know. I believe First gear was something like 3.12:1. Worked well with the 3.08 rear gear for starting on hills.
Driveable, but I always wished for a four speed.
My current ride is my '64Dog which has a NP420 transmission and Third gear is something like 1.7:1. Going up a long hill and want to shift down? Now the engine is screaming. It'd be so much nicer with a 1.4 Third.
R.
Re: over drive trans [Re: dogdays] #1496703
09/06/13 09:12 PM
09/06/13 09:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
R.
None of which is relevant to an A833OD.
If you have a gutless engine then you need more gears to crutch it along. My 64 300 with a warmed up 413 and an A745 three speed had no problems going up I8 east of San Diego, just add a bit more gas, no need to down shift. An A833OD would have simply dropped the cruising rpm because 1-2-3 were about the same ratios as the three speed.
Re: over drive trans [Re: Supercuda] #1496704
09/07/13 12:35 AM
09/07/13 12:35 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Shoot, no doubt about that. Cripes, I have a 318 two barrel, 2.94's in a 4100 pound half-ton and the 833od pulls that thing around no problem.
I'd be puttin' 2.76's in that '65; it's gonna be too quick with 3.55's.
Mo' Farts
Moderated by "tbagger".
