Re: over drive trans
[Re: feets]
#1496699
09/05/13 07:22 PM
09/05/13 07:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
lol, huge ratio drops, ha ha. I suppose if you were running a 4 cylinder in a D350 yeah it'd be a problem. But one wonders if you have actually ever driven one. I suggest you look at the ratios of three speed manuals of the same era and compare them to the A833OD, pretty close or "worse" and no one cries about huge ratio drops there. http://www.moparts.org/Tech/Archive/clutch/17.htmlI have a 65 Cuda, early A body, I am fitting an A833OD into. It has a 318 and a 3.55 rear gear.
[Re: BulletBob]
#1496701
09/06/13 10:19 AM
09/06/13 10:19 AM
Supercuda
About to go away
About to go away
up yours
Easier to do this swap and it was to put one into my 87 Diplomat. I am intimately familiar with what needs doing when converting over. I usually spend whatever time is needed to get the parts I need at a low cost. Took me two years to gather up the stuff to swap into the Diplomat, but it cost me under $500 to go from auto to stick. Cuda is on course for about the same cost.
[Re: Supercuda]
#1496704
09/07/13 12:35 AM
09/07/13 12:35 AM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
Shoot, no doubt about that. Cripes, I have a 318 two barrel, 2.94's in a 4100 pound half-ton and the 833od pulls that thing around no problem.
I'd be puttin' 2.76's in that '65; it's gonna be too quick with 3.55's.
Mo' Farts
Moderated by "tbagger".
