carter carburetor help #1496340
09/04/13 08:09 PM
09/04/13 08:09 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
I recently bought a 318 engine from a 1972 Plymouth Satellite to put into my '67 Fury. Ont the top of the carburetor there is a port that I have no idea what it is for or where it connects to. Any help will be greatly appreciated.
John
[image][/image]
Re: carter carburetor help [Re: plymguy] #1496341
09/04/13 08:50 PM
09/04/13 08:50 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
closed bowl vent valve....connects to charcaol cannister via rubber line
Re: carter carburetor help [Re: maxwedge1] #1496342
09/04/13 10:02 PM
09/04/13 10:02 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
My Fury doesn't have that canister. Can the port be blocked off or will that effect the performance? Thanks.
John
Re: carter carburetor help [Re: plymguy] #1496343
09/05/13 12:55 AM
09/05/13 12:55 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Do NOT block it off...that's your atmospheric vent to the bowl. If anything, just leave it as it is.
Re: carter carburetor help [Re: superwrench] #1496344
09/05/13 01:30 PM
09/05/13 01:30 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Yup, just leave it open. Won't hurt a thing.
Best thing you could do is eliminate it (2BBL) with the manifold. What I mean is, take the 2BBL manifold off, and put a 4BBL on it. I did with my 360, loved it. Never looked back.
Re: carter carburetor help [Re: plymguy] #1496345
09/05/13 01:51 PM
09/05/13 01:51 PM
Walton, Indiana
TimS Offline
TimS  Offline
Walton, Indiana
John
[image][/image]
Got one on my 72 Barraucda 318 2bbl. Those BBD's are good little carbs. Ran for years with my vent tube open without issues. It'll stumble on takeoff if you plug it.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: carter carburetor help [Re: TimS] #1496346
09/05/13 04:54 PM
09/05/13 04:54 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John
[image][/image]
This one never stumbled !!
Re: carter carburetor help [Re: 62maxwgn] #1496347
09/05/13 06:40 PM
09/05/13 06:40 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
John
[image][/image]
That one vents differently.
The emissions era carbs were designed to vent into the canister so none of the evil fumes could kill off plankton living under the polar ice caps.
- Stu Harmon
Re: carter carburetor help [Re: feets] #1496348
09/05/13 07:51 PM
09/05/13 07:51 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
Thanks for all of the responses. They were most helpful.
John
Re: carter carburetor help [Re: 62maxwgn] #1496349
09/05/13 09:47 PM
09/05/13 09:47 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Vac advance is the one on the passenger side. Choke diaphragm is the small one on the back. Big on the bottom of course is the PCV.
Good carbs. I love BBD's. I better model would be one with a "tin top." I think '76 and newer. The ones that have a bent PCV fitting are for slants. (I buy those!)
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: carter carburetor help [Re: 62maxwgn] #1496350
09/06/13 07:36 AM
09/06/13 07:36 AM
Walton, Indiana
TimS Offline
TimS  Offline
Walton, Indiana
John
[image][/image]
Not the same carb. Different venting.
Re: carter carburetor help [Re: TimS] #1496351
09/06/13 10:26 AM
09/06/13 10:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John
[image][/image]
You think nI didn't know that !!
