Re: idle issue
[Re: TJP]
#1496192
09/05/13 12:20 AM
09/05/13 12:20 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Perculating fuel has air bubbles in it. Engines are made to run on feul, not air bubbles.. Id say your heat soak is the cause of your troubles...
I am truckless..
Re: idle issue
[Re: 340SHORTY]
#1496193
09/05/13 12:36 AM
09/05/13 12:36 AM
Posts: 4,179 California
mickm
California
that does make sense...
540 hemi, stage V intake, 2 edelbrock 650 carbs, 3/8" line from the tank to a carter mechanical pump designed to do 5.5 psi for these carbs, 5/16" line from the pump to a filter to the carbs. A/F around 13:1 at idle.
