idle issue #1496190
09/04/13 04:30 PM
09/04/13 04:30 PM
California
mickm Offline OP
mickm  Offline OP
California
i'm having an issue where after the car has warmed up well and been driven a bit, the idle, which is normally steady around 900, drops to 650-700 or so. the engine will reach operating temp pretty quick and idles ok there, it seems to come after driving around for a bit.
now i know i am having issues with gas percolating that i haven't got around to solving yet, could this be a symptom of that?
Re: idle issue [Re: mickm] #1496191
09/04/13 11:35 PM
09/04/13 11:35 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
could be several things, more info needed, motor size, carb type etc.
BTT
Re: idle issue [Re: TJP] #1496192
09/05/13 12:20 AM
09/05/13 12:20 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Perculating fuel has air bubbles in it. Engines are made to run on feul, not air bubbles.. Id say your heat soak is the cause of your troubles...
I am truckless..
Re: idle issue [Re: 340SHORTY] #1496193
09/05/13 12:36 AM
09/05/13 12:36 AM
California
mickm Offline OP
mickm  Offline OP
California
that does make sense...
540 hemi, stage V intake, 2 edelbrock 650 carbs, 3/8" line from the tank to a carter mechanical pump designed to do 5.5 psi for these carbs, 5/16" line from the pump to a filter to the carbs. A/F around 13:1 at idle.
