Radiator painting question? #1496137
09/04/13 01:34 PM
09/04/13 01:34 PM
Cincinnati, Ohio
superbeedave Offline OP
Cincinnati, Ohio
Can you paint directly over copper on a radiator or does it need to have primer sprayed on it first? Thanks Dave,
Re: Radiator painting question? [Re: superbeedave] #1496138
09/04/13 01:38 PM
09/04/13 01:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes, no primer needed or would it be good to have it there. One coat of black is all I'd recommend.
Re: Radiator painting question? [Re: Challenger 1] #1496139
09/04/13 01:40 PM
09/04/13 01:40 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks Challenger 1!
Re: Radiator painting question? [Re: superbeedave] #1496140
09/04/13 04:42 PM
09/04/13 04:42 PM
MN
astrobuf Offline
astrobuf  Offline
MN
There are special radiator paints that should be used to avoid problems with thermal expansion and conductivity loss. Eastwood is amongst the folks that sell it. Use a very thin coat
Astrobuf
So, are you really a Rocket Scientist?
Re: Radiator painting question? [Re: astrobuf] #1496141
09/04/13 06:22 PM
09/04/13 06:22 PM
Cincinnati, Ohio
Cincinnati, Ohio
Eastwood's radiator black is what I used, turned out real well! Thanks!
