indy sr max wedge gasket ? #1496104
09/04/13 11:12 AM
09/04/13 11:12 AM
illinois
dodgeram1998 Offline OP
illinois
I cant find for the life of me the part# for the fel pro gasket I used to use on indy sr max wedge intake ports.
Heads fully ported by jeff at modern a year ago and now I finally have time to put the heads,intake, etc. on and smell some burnt rubber if I can source up on some intake gaskets LOL
Re: indy sr max wedge gasket ? [Re: dodgeram1998] #1496105
09/04/13 11:28 AM
09/04/13 11:28 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
To be honest I haven't used real intake gaskets for a long time. I put a thin coat of grey gasket maker on the heads and put the intake on. It works really well.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: indy sr max wedge gasket ? [Re: Jacob Pitt] #1496106
09/04/13 11:33 AM
09/04/13 11:33 AM
illinois
illinois
thanks for the reply
Re: indy sr max wedge gasket ? [Re: dodgeram1998] #1496107
09/04/13 12:20 PM
09/04/13 12:20 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Superformance 6414 or 6415
RIP Monte Smith
Re: indy sr max wedge gasket ? [Re: dodgeram1998] #1496108
09/04/13 12:30 PM
09/04/13 12:30 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Fel Pro 1218, MW & Indy heads.
Don
Re: indy sr max wedge gasket ? [Re: dodgeram1998] #1496109
09/04/13 05:36 PM
09/04/13 05:36 PM
illinois
illinois
I thank you all for the comments , another question is for port matching the gaskets ,, spray adhesive gasket to head then maybe then cut out the undersize gasket portion with razor blade , so the gasket air flow restriction is removed??????????
I would like to hear ?
Re: indy sr max wedge gasket ? [Re: dodgeram1998] #1496110
09/04/13 05:53 PM
09/04/13 05:53 PM
AndyF Online content
AndyF  Online Content
Yes that is the way to do it. Use the Superformance gaskets and then you'll be able to swap intakes a number of times before having to scrap the gasket off the head. I've used the same set of gaskets for 10+ intake swaps before.
Re: indy sr max wedge gasket ? [Re: AndyF] #1496111
09/04/13 06:49 PM
09/04/13 06:49 PM
illinois
illinois
Thanks for the info and heads up with the gasketst
Re: indy sr max wedge gasket ? [Re: AndyF] #1496112
09/05/13 11:02 AM
09/05/13 11:02 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Andy is this see through valley plate for dyno use only? Thanks, Don
Re: indy sr max wedge gasket ? [Re: cudadon] #1496113
09/05/13 01:10 PM
09/05/13 01:10 PM
I sell it as a dyno only part but it really depends on how hot the oil gets. On the dyno we keep the oil temp between 180 and 200 F. If you keep the oil in that range the clear cover should last a long time. Also depends if you're pulling a lot of vacuum or not. Hot oil and a lot of pan vacuum could cause a problem.
