Cuda gas filler tube
#1495607
09/03/13 03:26 PM
09/03/13 03:26 PM
Posts: 1,487 STL
cdstl
STL
Has anyone had any luck with "tinning" these tubes to get a somewhat factory looking finish? I have sweated plenty of pipes. I tried a quick test on a piece of steel tube the other day using flux and silver solder. Didn't work well. I don't couldn't get the piece of tube hot enough for the solder to flow.
Anyone?
thanks
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Cuda gas filler tube
[Re: burdar]
#1495609
09/03/13 03:37 PM
09/03/13 03:37 PM
Posts: 1,553 Sweden
71redcuda
Sweden
There is a guy who restores them. I think his prices are reasonable too.
Who?
[Re: 5carguy]
#1495613
09/08/13 06:04 PM
09/08/13 06:04 PM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
Try the Tinning Butter from Eastwood.Great stuff.
I've done several like this, worked out great! While it is still hot, I used a piece of steel wool to smooth out any drips, etc. Once cooled down, I went over it with steel wool once again. After a few weeks the surface will darken a bit and look 99% correct.
