need pictures of homemade air pans #1495457
09/03/13 11:19 AM
09/03/13 11:19 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I need ideas to fab up a dual quad air pan
I'm clueless
I bough the aluminum and Moroso foambut need ideas.
Re: need pictures of homemade air pans [Re: Sammy] #1495458
09/03/13 06:49 PM
09/03/13 06:49 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
this is the pan I made . I have used it with a single 4 barrel and with my dual quad modman , filter base bolts in . It is made of heatproof fibreglass , used in marine exhaust work and high density seat foam. this is under a six pack scoop .
IMO aluminium tray will transfer heat almost as fast as no tray . one of the guys on here does repop glass air cleaners , like the A12 and freshair units but can set them to suit your carb spacing and carb type .early AFB or later eddy/afb/holley . paintitblack(?)
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: need pictures of homemade air pans [Re: Sammy] #1495459
09/03/13 07:48 PM
09/03/13 07:48 PM
New York
1stBxMopar Offline
1stBxMopar  Offline
New York
This is the moroso aluminum and foam for single 4bbl. You can get it for dual 4bbl.............
Re: need pictures of homemade air pans [Re: 1stBxMopar] #1495460
09/03/13 09:24 PM
09/03/13 09:24 PM
Ohio
Todd Offline
Todd  Offline
Ohio
4" drop air cleaner base sheet of. 040 aluminum and some moroso foam.
The hold down is a handle off of the side of an aluminum harbor freight floor jack.
Found out that the foam cuts awesome with the bandsaw.
Added a 4" air filter and 3/4" thick ring of air pan foam to the underside of the hood that keeps the filter in place.
Saw a .2 gain and zero change by adding the air filter.
I made the pan as big as the hood scoop.
