Re: Six Pack: Why do they have secondary idle mixture adj?
[Re: ragtop]
#1495261
09/02/13 06:55 PM
09/02/13 06:55 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Theoretcally, what would happen if you turned all of the outboard carb screws, in all the way? Thanks.
They supply fuel to the forward and rear cylinders while at idle. If you shut them off a dangerous lean condition will likely occur, this can cause burned pistons, etc. That's why the factory adjusted them and staked them, to help keep owners from burning up their engines practicing their tuning skills.
[Re: ScottSmith_Harms]
#1495262
09/02/13 07:10 PM
09/02/13 07:10 PM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
the way I heard it is so the fuel is being used that is in the float bowls so at least there is fresh fuel coming in. not that there would be a problem with just jamming your foot down to use the outboards. also helps with the lean mixture that will happen when the outboards open because they don't have a pump shot.
[Re: lewtot184]
#1495264
09/02/13 10:59 PM
09/02/13 10:59 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Most 4 brll carbs and other extra carbs like 6pk's have idle circuits in the non primary brll's. Many 4 brll's have non adjustable idle circuits in the secondary's. Ron
[Re: ragtop]
#1495265
09/08/13 01:13 AM
09/08/13 01:13 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I'm running the old Direct Connection mechanical secondary, side hung float bowl carbs. The outboards on this set-up have no fuel/air circuits. It idles of the center carb only.
The factory outboards have fuel/air idle circuits on the end carbs to keep the fuel from stagnating if they are not opened for extended periods.
Due to the weight of my right foot, I don't seem to have that problem.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
