Six Pack: Why do they have secondary idle mixture adj? #1495260
09/02/13 06:45 PM
09/02/13 06:45 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
Why do Six Packs have idle mixture screws on the outboard carbs? Are they necessary? Theoretcally, what would happen if you turned all of the outboard carb screws, in all the way? Thanks.
Re: Six Pack: Why do they have secondary idle mixture adj? [Re: ragtop] #1495261
09/02/13 06:55 PM
09/02/13 06:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
They supply fuel to the forward and rear cylinders while at idle. If you shut them off a dangerous lean condition will likely occur, this can cause burned pistons, etc. That's why the factory adjusted them and staked them, to help keep owners from burning up their engines practicing their tuning skills.
Re: Six Pack: Why do they have secondary idle mixture adj? [Re: ScottSmith_Harms] #1495262
09/02/13 07:10 PM
09/02/13 07:10 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
the way I heard it is so the fuel is being used that is in the float bowls so at least there is fresh fuel coming in. not that there would be a problem with just jamming your foot down to use the outboards. also helps with the lean mixture that will happen when the outboards open because they don't have a pump shot.
Re: Six Pack: Why do they have secondary idle mixture adj? [Re: macmic87] #1495263
09/02/13 10:30 PM
09/02/13 10:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the chrysler carbs had them for emission concerns. chrysler built their emissions into the carbs and ignition. the corvette holley tri-power doesn't have them; they used an air pump for emissions..
Re: Six Pack: Why do they have secondary idle mixture adj? [Re: lewtot184] #1495264
09/02/13 10:59 PM
09/02/13 10:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Most 4 brll carbs and other extra carbs like 6pk's have idle circuits in the non primary brll's. Many 4 brll's have non adjustable idle circuits in the secondary's. Ron
Re: Six Pack: Why do they have secondary idle mixture adj? [Re: ragtop] #1495265
09/08/13 01:13 AM
09/08/13 01:13 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm running the old Direct Connection mechanical secondary, side hung float bowl carbs. The outboards on this set-up have no fuel/air circuits. It idles of the center carb only.
The factory outboards have fuel/air idle circuits on the end carbs to keep the fuel from stagnating if they are not opened for extended periods.
Due to the weight of my right foot, I don't seem to have that problem.
