raised venturis on dominator #1494643
09/01/13 09:56 PM
09/01/13 09:56 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
does the lengthen venture on the dominators(quick fuel) improve performance at all?
Re: raised venturis on dominator [Re: mopar dave] #1494644
09/01/13 10:00 PM
09/01/13 10:00 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I have often wondered the same thing. My friend has used Quick Fuel carbs a lot, I should ask him.
Alan Jones
Re: raised venturis on dominator [Re: LA360] #1494645
09/01/13 10:07 PM
09/01/13 10:07 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The new Holley Ultra 3 Dominators are 5/16 taller according to their add...So now you have two companies doing it....They just don't look like stub stacks like the QF carbs do.
Re: raised venturis on dominator [Re: Dragula] #1494646
09/01/13 10:14 PM
09/01/13 10:14 PM
Mt Morris Michigan
Mt Morris Michigan
qf has a new dominator that looks badazz.
http://i.ebayimg.com/t/Quick-Fuel-BD-QFX...OB+w~~60_12.JPG
Re: raised venturis on dominator [Re: mopar dave] #1494647
09/01/13 10:38 PM
09/01/13 10:38 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Holley had the raised venturi carbs years ago and now they have a blended radius at the top and there is a reason for that. The raised rings at the top do not flow near as well as the blended radius. It makes the air flow turbulent.
Monte
Re: raised venturis on dominator [Re: Monte_Smith] #1494648
09/01/13 10:52 PM
09/01/13 10:52 PM
SoCal
Brian Hafliger Offline
SoCal
Damn good to see you Monte!
We'll be testing the new Holley Gen3 1050 along with a QF 1050 on a 540 inch BB Mopar in the next couple of weeks. I'll post the info when I have it.
I'm expecting it to be kinda close between the 2 but you never know!
Brian Hafliger
Re: raised venturis on dominator [Re: Monte_Smith] #1494649
09/02/13 01:20 AM
09/02/13 01:20 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Monte
is this what you are talking about?
Re: raised venturis on dominator [Re: rebel] #1494650
09/02/13 01:31 AM
09/02/13 01:31 AM
Dragula Offline
Dragula  Offline
I dunno, I think I am still going with the SV1 this winter. I think it will have more throttle response and drive better..
Re: raised venturis on dominator [Re: rebel] #1494651
09/02/13 11:27 AM
09/02/13 11:27 AM
Mt Morris Michigan
Mt Morris Michigan
Re: raised venturis on dominator [Re: rebel] #1494652
09/02/13 11:31 AM
09/02/13 11:31 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I think this is what he's talking about Rebel.
Brian
Re: raised venturis on dominator [Re: '72CudaRacer] #1494653
09/02/13 11:38 AM
09/02/13 11:38 AM
Mt Morris Michigan
Mt Morris Michigan
yes,thats what I'm talkin about. have you tried any back to back runs with a smooth top vs the raised venture like the one in your pic?
Re: raised venturis on dominator [Re: mopar dave] #1494654
09/02/13 11:39 AM
09/02/13 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I never cared for the vertical wall on the inlet..
when I use to flow the carbs or air cleaners we always
put a "ideal entry"(basically a velocity stack) on
them for a smooth entrance... and if we didnt use it
we would see a air flow difference(always less)..
this is what I have mounted in my scoop
Re: raised venturis on dominator [Re: MR_P_BODY] #1494655
09/02/13 11:53 AM
09/02/13 11:53 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
From what I understand and have been told the purpose is to get the boosters lower in the throttle bore to increase the signal. In turn it atomizes the fuel better. Take a look at a Dam-Best billet carb and see how tall the body is.
Re: raised venturis on dominator [Re: mopar dave] #1494656
09/02/13 12:00 PM
09/02/13 12:00 PM
Mooresburg, Tn
Mooresburg, Tn
No, I haven't tried them back to back. We made 3 dyno pulls with it, and put it back in the box. (not on my engine) Health reasons and the weather here (RAIN) have kept me from testing it against my other 1050 Holley. I actually have this carb for sale in the Moparts adds now. I will make someone a deal on it. The Black Diamond finnish looks Killer though.
Brian
Re: raised venturis on dominator [Re: fbs63] #1494657
09/02/13 12:04 PM
09/02/13 12:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its true that if you move the booster down in the
faster air flow its sees a stronger signal... but to
bandage it with a vertical wall isnt helping the entry
air flow... so if the carb were built taller with
the boosters down in and with a smooth radius on
top then it would be great... but most people tend
to run out of room to the hood.... thats why the old
long stacks worked (gave the carb a tall entry to
speed up the air)
Re: raised venturis on dominator [Re: MR_P_BODY] #1494658
09/02/13 12:08 PM
09/02/13 12:08 PM
Mt Morris Michigan
Mt Morris Michigan
Re: raised venturis on dominator [Re: mopar dave] #1494659
09/02/13 12:34 PM
09/02/13 12:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
http://www.r2cperformance.com/assets/1/Products/800x600/P1010016.JPG
this is what I now use.
I dont like a drop base on a race car... the air has
to change directions when its entering the filter..
most of the filter is lower than the top of the base
so it has to go up then turn to head into the carb
Re: raised venturis on dominator [Re: MR_P_BODY] #1494660
09/02/13 12:41 PM
09/02/13 12:41 PM
Mt Morris Michigan
Mt Morris Michigan
yeah, I know Mike,but its the only way I get a filter under the hood. makes a difference what lid you use also. must be a bubble top lid like the moroso. not sure how i'll fit a dominator with filter under there. may have to settle on the race demon 1025rs.
Re: raised venturis on dominator [Re: mopar dave] #1494661
09/02/13 12:43 PM
09/02/13 12:43 PM
Mt Morris Michigan
Mt Morris Michigan
something R2C told me was in their testing of air cleaners,filters as well as others,that the worst was the filter lids. just an fyi.
Re: raised venturis on dominator [Re: mopar dave] #1494662
09/02/13 01:02 PM
09/02/13 01:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I heard that the lids are bad also.... but what
do I have... a filter lid(the whole filter set up was
cheap so I got it)... I'm still planning on getting
a lid.. to my understanding and through testting in
the past... with the 2 different air flow entrances
they crash into each other and cause turbulence in
the flow.... air... like water want to be nice and
smooth without turns or obstacles
