Dart rear window trim. #1494083
09/01/13 08:33 PM
09/01/13 08:33 PM
Streetsboro ,Ohio
72duster318 Offline OP
Streetsboro ,Ohio
OK, we had the glass put in the Dart, front had no problem, went to add the trim to the back and it isn't even close. Is there different trim for different years? It was my belief that everything from about 67 to 75 was the same. Hard to tell in the picture bur the top is flat instead of arched, and the sides are a little too short and bottom is arched differently.
If you didn't build it yourself, it's not really yours - Tim "the toolman" Taylor
Re: Dart rear window trim. [Re: 72duster318] #1494084
09/01/13 09:54 PM
09/01/13 09:54 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Remember, everything bends and twists when you install the rear trim. Those are some complex bends to go around that window. IIRC when I put mine in I was scratching my head also, but it went in very nicely.
Re: Dart rear window trim. [Re: 70HemiGTX] #1494085
09/01/13 10:30 PM
09/01/13 10:30 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
Maybe you have trim from a 4-door, or 2-door post car.
I dont know that the rear windows are different, but I know the windshields are different between the post car and the hardtop.
I accidentally bought a front windshield gasket for a 2-door post and it was a little to short for my hardtop windshield opening. Rears may be different too. Not sure.
Re: Dart rear window trim. [Re: MileHighDart] #1494086
09/02/13 11:09 AM
09/02/13 11:09 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The rear window trim is the same from 68-72 for 2-door hardtops and 2-door sedans and 4-door sedans have the same trim too. Where did you get your trim at?
JB Rhinehart, Realist
A-Body's RULE!
Re: Dart rear window trim. [Re: Rhinodart] #1494087
09/02/13 07:29 PM
09/02/13 07:29 PM
Streetsboro ,Ohio
Streetsboro ,Ohio
I think we picked it up at Carlisle in the swap area
Re: Dart rear window trim. [Re: 72duster318] #1494088
09/02/13 09:07 PM
09/02/13 09:07 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I checked my parts books from 1967 to 1974. As already mentioned, the hardtop mouldings are different from the sedan ones. '67-'74 hardtops use one set of part numbers while '67 to '74 sedans use a different set of part numbers. By any chance are there any Dart sedans in your area that you could compare your mouldings to? That would tell you if they are hardtop or sedan ones.
Re: Dart rear window trim. [Re: moparfan53] #1494089
09/02/13 09:54 PM
09/02/13 09:54 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is what I was trying to say, thanks for making it more clear as I sometime tend to type before I think.
A-Body's RULE!
Re: Dart rear window trim. [Re: Rhinodart] #1494090
09/03/13 10:27 PM
09/03/13 10:27 PM
Streetsboro ,Ohio
Streetsboro ,Ohio
Thanks for the replies, I'll remember to look at the local cruises to see if any are flat across the top instead of arched.
Re: Dart rear window trim. [Re: 72duster318] #1494091
09/04/13 12:01 AM
09/04/13 12:01 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
These pics from sales brochures might help. It looks to me that the sedan rear window is slightly flatter at the top than the hardtop. It also looks like the sedan sides are shorter due to the window slope. I would say you do have the sedan trim.
Re: Dart rear window trim. [Re: moparfan53] #1494092
09/04/13 12:29 AM
09/04/13 12:29 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have plenty of hardtop rear window trim if you have trouble finding any!
A-Body's RULE!
Re: Dart rear window trim. [Re: MileHighDart] #1494093
09/04/13 06:43 AM
09/04/13 06:43 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Yes they are different.
