Re: No Reverse
[Re: mightycuda]
#1493424
08/31/13 10:05 AM
08/31/13 10:05 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Possible L/R band failure, L/R servo issue (cracked piston or blown seal). Could have an issue with the front clutch pack also. You will be missing 3rd gear if it has an issue. Will vehicle still roll in reverse or does it bind up? If it binds and wont move either direction could be and issue with the rear clutch pack (forward clutches) welded together causing no reverse. Your just going to have to drop the pan and have a look. You can fix a servo issue with the trans in the car. If the band is broken or you have a clutch pack issue, the tranny is going to have to come out.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
Re: No Reverse
[Re: mightycuda]
#1493427
08/31/13 02:17 PM
08/31/13 02:17 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Started the car and it was just at normal idle. Put it into reverse and started to back up but it felt funny and kinda stopped, put in forward and pulled up a few feet and tried reverse again and nothing. Was hoping it would be something minor as it has been fine til yesterday.
Drop the pan , reverse is the rear band applied and the front clutch pack applied , you lost one of 3 things , the rear band broke , the rear servo is not working or the front clutch pack is no longer working or holding.
Re: No Reverse
[Re: JohnRR]
#1493428
08/31/13 07:39 PM
08/31/13 07:39 PM
Posts: 25,933 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's not uncommon for the rear band link to pop out, easy fix after the pan is removed.
