Page 4 of 14 1 2 3 4 5 6 13 14
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492884
09/03/13 03:17 PM
09/03/13 03:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just a faster curve on the 14 advance with lighter springs will hold it off the stop so say idling in gear at 28 (so 9 mechanical advance in) with another 5 mechanical advance to go as rpm comes up.
without driving you can test how it will respond to more in gear idle advance by advancing it till you have 28 in gear and fiddle with idle see how it likes it I know this would be 42 total but at this point your not driving just finding a nice idle.
Then you tailor you advance springs to get it to idle at that advance but still have your 33 to 36 total.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492885
09/03/13 03:24 PM
09/03/13 03:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I used to run 30 degrees in the dizzy with light springs so all in by 1200 rpm and most in by my 1100 idle with a bigger cam than yours. (or similar cam smaller motor)
I don't drive on the street any more and have a MSD with the 25 stop in light mopar springs advance is all in at my 1200 idle. basically I use advance for ease of starting.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492886
09/03/13 03:26 PM
09/03/13 03:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Just a faster curve with lighter springs will hold it off the stop so say idling in gear at 28 (so 9 mechanical advance in) with another 5 mechanical advance to go as rpm comes up.
Re: Cam break in is done!....Now more questions! [Re: Dodgem] #1492887
09/03/13 03:35 PM
09/03/13 03:35 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Dodgem:
Trying to wrap my head around this.... With the distributor at rest, the springs relaxed, your theoretical timing is lower at cranking..... but the light springs stretch once the engine fires they advance some, then you have another "stage" of advance?
Is this done by using a light spring on one weight and a heavy one on the other?
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492888
09/03/13 04:09 PM
09/03/13 04:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
At present you may (probably) not getting any advance at idle just what you set to. It takes more RPM's to start stretching the stiff springs to get some of that 14 mechanical advance.
But put lighter springs in and idle rpm should be enough to allow some stretch and some mechanical advance. so say if you put the lightest springs in that came with your dizzy 950 rpm may allow dizzy to advance lets say 8 deg so that will give you 19 + 8 = 27 advance at 950 instead of it sitting at 19 total in both cases is still 33.
so one light spring may do it maybe needs too it's trial and error.
But as i said you can at idle turn dizzy till you get say 27 then mess with idle if it's good then tailor your advance springs to get you there after turning dizzy back to where it was.
Re: Cam break in is done!....Now more questions! [Re: Dodgem] #1492889
09/03/13 04:50 PM
09/03/13 04:50 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks, Dodgem.
I just drove the car after putting the air cleaner on. It was running PIG rich in gear! It was dropping in the 11.0 range but it was still pinging.
Huh?
I expected the addition of the air cleaner to richen it up some, but now it looks like I'll have to go back at least 4 jet sizes to get close.
I'm amazed though that it still pinged. I would think that an over-rich condition would have stopped that by a longshot.
I'm going to pull a plug and check the cranking compression. Before the cam swap, I was at 185-192. This cam has a later intake closing, so I really expected it to reduce cylinder pressure so it would NOT detonate given the same tune as with the '509 cam.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492890
09/03/13 05:02 PM
09/03/13 05:02 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""It was running PIG rich in gear!""
On your next drive, after the engine is up to running temp, find a quiet parking spot and apply your emergency brake (or have a friend apply the brake) with the tranny in D. Then spend some time tuning your metering screws to achieve the highest vacuum reading while readjusting your idle after each adjustment (if needed). You should be able to tune it in D (13's or so) if you have enough initial timing.
"" It was dropping in the 11.0 range but it was still pinging.""
Was it pinging while showing 11.0 or did it ping under accel before it hit 11.0?
What was your leanest reading while you were out driving?
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492891
09/03/13 06:54 PM
09/03/13 06:54 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Thanks, Dodgem.
Huh?
I am not surprised that you may need to jet down some as you are 4 jet sizes over what I am running on my 500 stroker. However, I wouldn't worry too much about the carburetor tuning yet.
As mentioned before, you need to get your base timing down. I would give it as much base timing as possible before you start getting the kick back on the starter and then back off a degree or two. This should also yield a higher vacuum reading at idle which you will want to maximize. Once you do that, you then need to set the idle screws (also for max vacuum). Then set curb idle...probably relatively high for the cam you have...maybe 900-1100 RPM's or so?
Next you can deal with the jets and use your sensor to nail down the optimum size(s) to use. My dyno guy seemed to like to see around 13 or so under WOT...closer to 14-14.5 under lighter load.
I am guessing that you may still have the pinging problem and this may take some experimenting to fix. You may have some cooling issues from earlier posts...fix them so the engine is running <195* or so. You should be able to get that motor to advance to 34* or so without pinging...if not you may need to think about better fuel. Yeah you can dial back the total timing to keep it under 30* but this seems to be a band-aid and not a true 'fix'. You may find you will need to blend in some race fuel to get her happy. :-(
Either way, I wouldn't want to dial the timing way back which affects vacuum and how well the engine runs just to avoid the pinging if a gallon or two of race fuel per tank might fix ya!
Otherwise, you ma look into a thicker head gasket and see if you can shave a little off the compression but I think the engine temperatures being kept in check will go a long way here.
Does the motor still die after 15 minutes or is that been fixed? You had some other issues I seem to recall....
Re: Cam break in is done!....Now more questions! [Re: cjskotni] #1492892
09/03/13 09:43 PM
09/03/13 09:43 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The closer I get, the further away I am.
Earlier I wrote that after the cleaning of the air bleeds and the UPjetting to #90 primaries, I was running waaay rich. It still pinged. I didn't run it to full throttle to see the A/F readings because of the pinging. It wasn't rattling nearly as bad as it has in the past, but it was there.
I came back and went back to the #88 jets. The A/F numbers leaned out a bit but it was still rich under load around 12.5 to 13.5. It still pinged as well.
The opinions I get on this brand of carburetor range from either guys with no comment to guys saying they are junk. Almost everyone that complained about them says they picked up speed and reliability with a Holley.
Tomorrow I'll put my 750 back on for a road test. If it still runs rich or detonates with this totally stock, UNmodified carb, I'll have to look elsewhere for the problem. I suspect that the Demon is a POS though. After I put in the #88 jets, the idle in Park A/F numbers really leaned out and the IN GEAR idling almost went full lean past 17.0. Its as if I am dancing around a goal that the carb isn't equipped to meet.
Oh, regarding RACE gas:
The entire point of changing to this cam was to achieve a later intake closing, reduce cylinder pressure and increase detonation resistance. Running race gas shouldn't be necessary. I checked one cylinders compression today and gor a 173 reading. That hole showed 188 with the 509 cam.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492893
09/04/13 02:40 PM
09/04/13 02:40 PM
ill
dennismopar73 Offline
ill
What ever is going on carb will normaly run very close to factory sets on just about any motor,
trying to over come high comression yet run reg cheapo gas is usaually a run at insanity at best,
1 has to either lower the compression or run at race sttings
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492894
09/04/13 03:39 PM
09/04/13 03:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
At 173 cranking you should be able to run 91 with a good working carb.
I've been as high as 210 on 94 sunoco.
what is your stall speed.
If all else fails do a compression check on all 8?
jet that 750 up 2 or 3 sizes to make up for the 10% ethanol.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492895
09/04/13 03:57 PM
09/04/13 03:57 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Beyond all that you've been through here...
Have you tried a good shot of 110???
Re: Cam break in is done!....Now more questions! [Re: RSNOMO] #1492896
09/04/13 04:09 PM
09/04/13 04:09 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I ran some 110 leaded with the 509 cam setup. It ran fine with zero detonation. The thing is, a few years back, it ran fine on 91 with the same timing. Maybe some of that is due to the ethanol in the fuel, but I wonder if most lies in this carburetor.
Converter stall speed? Sorta hard to tell. Its a 9 3/4" unit that was built to be a 3000 stall. I didn't like the lazy way it felt so I had the builder cut it open and change a few parts inside. It stalls lower than that now.
When I'm stationary in gear holding the brake, it will start spinning the tires on concrete at around 2200 or so. Asphalt would probably be higher.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492897
09/04/13 06:18 PM
09/04/13 06:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That's tight the tighter the stall the sooner the engine loads.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492898
09/04/13 06:18 PM
09/04/13 06:18 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I'm not questioning you here, but, I don't know how...
I've got a 440 with a 484 that doesn't run for scat unless I spike it...
Compression is borderline...Six-Pack piston under a 452 head with a steel gasket...
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492899
09/04/13 06:23 PM
09/04/13 06:23 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I wish I had some good news here. I know that many members have chimed in trying to help.
The 750 made the engine idle much smoother. I was actually able to get it to idle down to 600 in gear without stalling. I wasn't able to do that with the 850 because below 700, it loped around and felt ready to stall.
The A/F numbers looked decent. Idle was in the 14.0 to 14.5 range and while sitting at a stoplight, it was in the 13.8 to 14.2 range. I was amazed at how docile the engine seemed. Part throttle A/F was just below 12.5 and no higher than 13.4, so that seemed within range.
It still detonated at 3/4 throttle and above. I even reset the timing to 17 initial and 31 total before the drive.
Everything that I have tried since the cam swap has resulted in detonation. Bigger jets, smaller jets. Bigger PVs, smaller ones. Different timing settings. Different distributors. A different carburetor. Different weather outside. Cool engine, warm engine. The only time it ran without spark knock was when I had the timing set to 6 initial and 20 total. That was only a test to assess things. I would never expect this engine to run right at that setting.
Currently, I am out of ideas.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492900
09/04/13 06:28 PM
09/04/13 06:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
does it do it if you run it up to 4000 then feed her some power??
Re: Cam break in is done!....Now more questions! [Re: Dodgem] #1492901
09/04/13 06:32 PM
09/04/13 06:32 PM
California
mickm Offline
mickm  Offline
California
don't know if this has been covered before, but are you sure it is detonation? maybe an exhaust leak? just throwing things out, but i guess you said it did go away with the retarded timing.
maybe it has more compression than you think? even with the new cam bleeding some of that off, it isn't enough?
don't know... i know comparing a hemi and a wedge isn't a real comparison, but i'm around 10.25-10.4:1, 210 psi hot cranking, and i have yet to hear the thing ping.
Re: Cam break in is done!....Now more questions! [Re: Kern Dog] #1492902
09/04/13 07:10 PM
09/04/13 07:10 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Did you ever check the fuel pressure under WOT? What spark plug are you using?
Re: Cam break in is done!....Now more questions! [Re: mickm] #1492903
09/04/13 07:18 PM
09/04/13 07:18 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I agree here. I think with a 10.7:1 compression, you will have your work cut out for you to run this on pump gas...especially with the ethanol swill we have available today. Even with the aluminum heads, I think you are going to have a temperamental engine if you don't spike it with some race fuel. It's also possible maybe your compression ratio is a tad higher than you calculated.
The rule of thumb I hear is 9.5:1 max for iron heads and add a point for aluminum heads so you are a little past the border. I am sure somebody here will chime in that they run more than that on pump gas but every engine build is different. I agree with your logic on the cam choice but maybe not enough cam to bleed it all off?
If this were my motor, I would start with a head gasket change. I used the thick FelPro's on my build (.055" compressed) which helped bring my calculated compression down almost .2 points from the thin gaskets. With thinner gaskets (.039"), I would have been closer to a 10.6:1 which kind of made me worry about being in the same boat as you.
If the AF ratio isn't way lean @ WOT, then you really have two more things to try and fix here. Verify the engine is NOT running hot and/or lower the compression.
I would try to avoid retarding the timing any more than 31* total and that is too retarded in my opinion.
You will get there and your car will burn rubber (reliably) before you know it!
