Lenco Transmission info for a 1966 plymouth satellite. #1492812
08/29/13 11:48 PM
08/29/13 11:48 PM
Maryville tn
67coronetman Offline OP
Maryville tn
I was wondering if anyone out here is using or has any lenco trans info on what it takes to put one in a 66 B-Body thanks for any help.
Old car are me......
Re: Lenco Transmission info for a 1966 plymouth satellite. [Re: 67coronetman] #1492813
08/30/13 11:08 AM
08/30/13 11:08 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You will have to cut a very large hole in the floor and trim the trans cross member to clear the Lenco. Other than that you can get a bellhousing from several sources and use whatever clutch/pp to suite you application.
Re: Lenco Transmission info for a 1966 plymouth satellite. [Re: Jeremiah] #1492814
08/30/13 08:22 PM
08/30/13 08:22 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
There's a member here who put one in a Challenger with a Hemi & made Car Craft or Hot Rod mag with it 30 years ago or so.
Maybe he will chime in on the experience
Re: Lenco Transmission info for a 1966 plymouth satellite. [Re: Jeremiah] #1492815
08/30/13 10:03 PM
08/30/13 10:03 PM
Maryville tn
Maryville tn
Thanks for the info.
Re: Lenco Transmission info for a 1966 plymouth satellite. [Re: 67coronetman] #1492816
08/30/13 11:10 PM
08/30/13 11:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you really NEED a Lenco or do you just like the idea of pulling levers like the old Pro-Stock videos? I could think of a few other options that I would spend 8-10 grand on myself
Go to www.umtrnorth.com for some answers.
Gus
64 Plymouth Savoy
Dana 60
