where is the coolant coming from? 426 Hemi "UPDATE" #1492417
08/29/13 01:07 PM
08/29/13 01:07 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
The last couple of days I have been seeing coolant on top of the oil pump. I dont remember if the hemi is like a wedge and header bolts go into the coolant. I am finding the coolant on the inner piece of the housing where the outer piece of the housing goes up against it. There is a low area there. We are talking about less than a thimble off coolant a day. Motor has less than 20 miles on it and is all new parts.
Re: where is the coolant coming from? 426 Hemi [Re: maxie] #1492418
08/29/13 01:38 PM
08/29/13 01:38 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
IIRC, the front header bolts on No. 1 cylinder go into the Head bolt hole, the rear 2 are blind but if they are drilled too deep they could break into water, if so, a bit of silicone will fix it. Also possible that you are leaking at the top front corner of head and the coolant is running down front edge of head onto oil pump.
Be a Rebel- Break the Laws of Physics!
Re: where is the coolant coming from? 426 Hemi [Re: mbogina] #1492419
08/29/13 02:28 PM
08/29/13 02:28 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Hemis have a habit of leaking at the front and back of the heads at the large coolant passages(see outward bump in head casting),pressurize the system amd check these areas for coolant leaks.
Re: where is the coolant coming from? 426 Hemi [Re: B G Racing] #1492420
08/29/13 02:53 PM
08/29/13 02:53 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Yep. Sometimes if it just a suttle leak radiator pellets will fix it. Go to a GM dealer and buy them, they work really well.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: where is the coolant coming from? 426 Hemi [Re: HemiDart68] #1492421
08/29/13 04:38 PM
08/29/13 04:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Always check the head gaskets in this area since the block and heads coolant holes vary from manufacture to manufacture.We usually put silicone around these areas for extra insurance.
Re: where is the coolant coming from? 426 Hemi [Re: B G Racing] #1492422
08/29/13 05:05 PM
08/29/13 05:05 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I have had that happen when I put the head gaskets on dry per the manufacturers specs. So then I had to take the heads back off and spray copper coat on them like I wanted to do in the first place and then they didn't leak. As said above, the exhaust bolts and the head bolts are dry on a hemi.
2011 Drag Pak Challenger
Re: where is the coolant coming from? 426 Hemi [Re: B G Racing] #1492423
08/29/13 05:14 PM
08/29/13 05:14 PM
dogdays Offline
dogdays  Offline
Pellets you can find in the plastic bottles of Bars Leaks at your local WalMart. Not the absolutely cheapest version, the next step up in price. The bottle is clear in some areas, be sure to shake it up so all the little pellets roll out into the radiator.
For the head gasket water leaks I would suggest that blue Rolls-Royce stuff (forgot the name but it is better than silicone for this application.)
R.
Re: where is the coolant coming from? 426 Hemi [Re: maxie] #1492424
08/29/13 06:12 PM
08/29/13 06:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I add a bottle of Bars Leak to every build I do..
I silicone the head and exhaust studs also, just in
case they are drilled deep... then the bottle of stop
leak is just insurance
Re: where is the coolant coming from? 426 Hemi [Re: dogdays] #1492425
08/29/13 06:25 PM
08/29/13 06:25 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
R.
Blue Hylomar!
Re: where is the coolant coming from? 426 Hemi [Re: MR_P_BODY] #1492426
08/30/13 04:27 AM
08/30/13 04:27 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Same here, bars leak in every build I do and no problems ever.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: where is the coolant coming from? 426 Hemi [Re: MrSixpack] #1492427
08/30/13 02:12 PM
08/30/13 02:12 PM
dogdays Offline
dogdays  Offline
Thanks, you son of Odin!
Hylomar is neat stuff and everyone should have a tube or two lying around to seal up those nasty areas.
R.
Re: where is the coolant coming from? 426 Hemi [Re: dogdays] #1492428
09/01/13 04:27 PM
09/01/13 04:27 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
After I posted this I went out and looked at the area where the head bolts on.
I wiped down the head and front of the block real good with a rag and have not seen anymore coolant on the oil pump.
I had changed the thermostat a few days earlier and didnt know if the fan sucked coolant all over the motor that I may have spilled while filling it up
Re: where is the coolant coming from? 426 Hemi [Re: maxie] #1492429
09/01/13 04:29 PM
09/01/13 04:29 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Also when I was wiping it off a little paint came off the bottom of the head, where it over hangs from the deck. I thought maybe water had leaked and was trapped in there when we fired it up for the first time.
Have not started the car since I have wiped it all down., may only leak after running
Re: where is the coolant coming from? 426 Hemi [Re: maxie] #1492430
09/03/13 02:27 PM
09/03/13 02:27 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
You should have bought my HEMI car......it never leaked water. Now oil is another topic.
