where is the coolant coming from? 426 Hemi "UPDATE"
#1492417
08/29/13 01:07 PM
08/29/13 01:07 PM
Posts: 7,063 Indiana
maxie
Indiana
The last couple of days I have been seeing coolant on top of the oil pump. I dont remember if the hemi is like a wedge and header bolts go into the coolant. I am finding the coolant on the inner piece of the housing where the outer piece of the housing goes up against it. There is a low area there. We are talking about less than a thimble off coolant a day. Motor has less than 20 miles on it and is all new parts.
Re: where is the coolant coming from? 426 Hemi
[Re: maxie]
#1492418
08/29/13 01:38 PM
08/29/13 01:38 PM
Posts: 293 Kansas City Metro
mbogina
Kansas City Metro
IIRC, the front header bolts on No. 1 cylinder go into the Head bolt hole, the rear 2 are blind but if they are drilled too deep they could break into water, if so, a bit of silicone will fix it. Also possible that you are leaking at the top front corner of head and the coolant is running down front edge of head onto oil pump.
Be a Rebel- Break the Laws of Physics!
[Re: HemiDart68]
#1492421
08/29/13 04:38 PM
08/29/13 04:38 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Hemis have a habit of leaking at the front and back of the heads at the large coolant passages(see outward bump in head casting),pressurize the system amd check these areas for coolant leaks.
Yep. Sometimes if it just a suttle leak radiator pellets will fix it. Go to a GM dealer and buy them, they work really well.
Always check the head gaskets in this area since the block and heads coolant holes vary from manufacture to manufacture.We usually put silicone around these areas for extra insurance.
[Re: B G Racing]
#1492422
08/29/13 05:05 PM
08/29/13 05:05 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have had that happen when I put the head gaskets on dry per the manufacturers specs. So then I had to take the heads back off and spray copper coat on them like I wanted to do in the first place and then they didn't leak. As said above, the exhaust bolts and the head bolts are dry on a hemi.
2011 Drag Pak Challenger
[Re: maxie]
#1492424
08/29/13 06:12 PM
08/29/13 06:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I add a bottle of Bars Leak to every build I do.. I silicone the head and exhaust studs also, just in case they are drilled deep... then the bottle of stop leak is just insurance
[Re: dogdays]
#1492425
08/29/13 06:25 PM
08/29/13 06:25 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Pellets you can find in the plastic bottles of Bars Leaks at your local WalMart. Not the absolutely cheapest version, the next step up in price. The bottle is clear in some areas, be sure to shake it up so all the little pellets roll out into the radiator.
For the head gasket water leaks I would suggest that blue Rolls-Royce stuff (forgot the name but it is better than silicone for this application.)
R.
Blue Hylomar!
