62-63 b-body 8 3/4 #1492230
08/29/13 01:38 AM
08/29/13 01:38 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
might be gettin this 63 b-body 8 3/4 rearend for a very good deal.i know it has the tappered axles and the nut in the center of axle.i was wonder what the length of the axles were? i was goin get some custom made axles for it or get some c-body 8 3/4 or truck axles have them cut down.so i can rid of the tappered setup it has.
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492231
08/29/13 02:05 AM
08/29/13 02:05 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I offer a 1 piece axle package for '62-'63 B-body rears.
E-mail me if you are interested.
Re: 62-63 b-body 8 3/4 [Re: DoctorDiff] #1492232
08/29/13 05:53 AM
08/29/13 05:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The C body and truck axles wont work in the 62/64 rearends . You would need to cut your ends off and weld on the 65 and newer ends. Theres a difference in the bearings..
Dr Diff is your go to guy in this case..
I am truckless..
Re: 62-63 b-body 8 3/4 [Re: 340SHORTY] #1492233
08/29/13 11:33 AM
08/29/13 11:33 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yup, go directly to DrDiff.
Re: 62-63 b-body 8 3/4 [Re: 340SHORTY] #1492234
08/29/13 11:34 AM
08/29/13 11:34 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Ebody rears will swap in. IIRC
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 62-63 b-body 8 3/4 [Re: Rug_Trucker] #1492235
08/29/13 11:39 AM
08/29/13 11:39 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Although they are wider, '65-'70 B-body rears will bolt in '62-'63 B-bodies.
E-body rears are wider yet, and require modification.
Re: 62-63 b-body 8 3/4 [Re: DoctorDiff] #1492236
08/29/13 01:28 PM
08/29/13 01:28 PM
las vegas,nv
las vegas,nv
just need axles only.maybe puttin in a 71 440 dart if i get it.
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492237
08/29/13 03:21 PM
08/29/13 03:21 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I put a 65 B-body Plymouth rear in my 63 and it fits and works great. I would either find a 65-70 rear or let Dr Diff set you up. Ron
Re: 62-63 b-body 8 3/4 [Re: 383man] #1492238
08/29/13 05:31 PM
08/29/13 05:31 PM
las vegas,nv
las vegas,nv
i see is a little shorter then a 65 is. all i own are a-bodies mopars
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492239
08/30/13 09:30 PM
08/30/13 09:30 PM
las vegas,nv
las vegas,nv
no ones the axles lengths of a 62-63 8 3/4 b-body?
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492240
08/30/13 11:06 PM
08/30/13 11:06 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I will guess... 21 7/16"
I am truckless..
Re: 62-63 b-body 8 3/4 [Re: 340SHORTY] #1492241
08/31/13 01:35 AM
08/31/13 01:35 AM
las vegas,nv
las vegas,nv
really u owned one?
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492242
08/31/13 01:58 AM
08/31/13 01:58 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
No,,, I used simple math and used the mearurements for the various 8 3/4 rears provided in the Tech Section..
but if you made a call to Dr Diff he could tell you exactly what tength they are..
I am truckless..
Re: 62-63 b-body 8 3/4 [Re: 340SHORTY] #1492243
08/31/13 03:50 AM
08/31/13 03:50 AM
las vegas,nv
las vegas,nv
ok i knew it was in the low 20's the length was.
Re: 62-63 b-body 8 3/4 [Re: Rug_Trucker] #1492244
08/31/13 04:26 AM
08/31/13 04:26 AM
Rug_Trucker Offline
Rug_Trucker  Offline
I am sorry! I was recalling an E body into a '60 Fury C body!
Re: 62-63 b-body 8 3/4 [Re: Rug_Trucker] #1492245
08/31/13 11:38 AM
08/31/13 11:38 AM
las vegas,nv
las vegas,nv
ok i see,its cool
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492246
08/31/13 07:43 PM
08/31/13 07:43 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The '62-'63 axles are tapered so they don't relate to flanged axle lengths but they are around 30 1/2" overall length. (end of splines to end of thread)
Re: 62-63 b-body 8 3/4 [Re: John_Kunkel] #1492247
09/01/13 01:32 PM
09/01/13 01:32 PM
las vegas,nv
las vegas,nv
oh ok i see.
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492248
09/01/13 05:54 PM
09/01/13 05:54 PM
Rio Linda, CA
Rio Linda, CA
If you're looking for the equivalent flanged axle length to fit the '62-'63 B-body housing it would depend on whether or not the center section is original and whether it has Sure-Grip or not (prior to '64 axle lengths changed with Sure-Grip or not).
To replace the tapered axle with a flange axle in a Sure-Grip rear end you'd need an axle length of around 25 7/8" which is well within the range that can be attained using a shortened/resplined factory axle.
Re: 62-63 b-body 8 3/4 [Re: John_Kunkel] #1492249
09/01/13 06:46 PM
09/01/13 06:46 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
53.25(housing width) + .25(2 backing plate) + 4.8(2 flange stand-out) -1.5(thrust block) = 57.05
Axle length = 57.05/2 = 28.4
Only a few stock axles can be shortened to yield this length.
