Best way to mount an aftermarket aluminum radiator? #1492179
08/29/13 12:25 AM
08/29/13 12:25 AM
Tampa, Florida
Road Ronin Offline OP
Tampa, Florida
I've heard diametrically opposed opinions about how to do this without vibration causing breakage to the aluminum:
1) weld custom pieces to the radiator so that it bolts in just like the original.
2) fabricate clamping brackets to hold it in place, using rubber spacers to dampen vibration.
Thanks in advance for setting me straight on this.
Leslie will lose; your automobile will lose; I WILL WIN! I shall build the greatest automobile in the world and I will win! Fate the Magnificent! MUAHAHAHAHAHA!!!
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492180
08/29/13 12:32 AM
08/29/13 12:32 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I've direct/solid mounted a few aluminum radiators in different cars and never had a problem for what it's worth..
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492181
08/29/13 12:40 AM
08/29/13 12:40 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I made a cradle for mine (of steel), that the mounting flange lies in. The cradle has 2 studs on the bottom that sit in holes in the body. For the top, drilled some holes through the flange and it's secured with bolts to the radiator support.
It's been like that for 5+ years, no problems.
Re: Best way to mount an aftermarket aluminum radiator? [Re: Exit1965] #1492182
08/29/13 06:52 PM
08/29/13 06:52 PM
Tampa, Florida
Tampa, Florida
Thanks guys. Do either of you have pictures you can share?
Re: Best way to mount an aftermarket aluminum radiator? [Re: OzHemi] #1492183
08/29/13 07:58 PM
08/29/13 07:58 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've direct/solid mounted a few aluminum radiators in different cars and never had a problem YET for what it's worth..
I just use rubber between the rad and mount with a bolt and nylock nut. It can be fuel line cut into short lengths, rubber grommets or pretty much any piece that will fit. I have done a few "hard mounts" like OZ and never had any cracking issues YET though.
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492184
08/29/13 08:11 PM
08/29/13 08:11 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Here is the tabs welded onto the radiator..
Re: Best way to mount an aftermarket aluminum radiator? [Re: OzHemi] #1492185
08/29/13 08:13 PM
08/29/13 08:13 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Bolted it up... (looking for a pic from the engine side, but you get the idea at least.. )
Re: Best way to mount an aftermarket aluminum radiator? [Re: OzHemi] #1492186
08/29/13 08:15 PM
08/29/13 08:15 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Best way to mount an aftermarket aluminum radiator? [Re: OzHemi] #1492187
08/29/13 08:16 PM
08/29/13 08:16 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Best way to mount an aftermarket aluminum radiator? [Re: OzHemi] #1492188
08/29/13 08:21 PM
08/29/13 08:21 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
And just for the heck of it.
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492189
08/29/13 09:16 PM
08/29/13 09:16 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I bought a 22" Champion radiator that was advertised to fit my Challenger with mounting brackets with holes already welded on.
I had to drill 1 hole that didn't line up to the factory bolts holes in the radiator support then bolted it in.
Everything fit perfect and the hose inlets were in the correct locations to use factory molded hoses.
Has kept my 440 Six Pack Challenger running at 160 degrees all summer.
Re: Best way to mount an aftermarket aluminum radiator? [Re: KillerBee] #1492190
09/01/13 01:02 AM
09/01/13 01:02 AM
Tampa, Florida
Tampa, Florida
Thanks OzHemi and KillerBee! Those pix are helpful.
And your engine bay looks gorgeous, Oz.
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492191
09/01/13 01:09 AM
09/01/13 01:09 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Thank you!
It took some work, but I am happy with how it came out.
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492192
09/01/13 01:14 AM
09/01/13 01:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I modified some Ford radiator brackets. Works great.
Re: Best way to mount an aftermarket aluminum radiator? [Re: Road Ronin] #1492193
09/01/13 11:17 AM
09/01/13 11:17 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If the original rad was alum, that would give some guidance as to how to mount tabs.
I don't think the main purpose of rubber mounting is to to isolate vibration, more to prevent radiator from becoming a structural member of the chassis. Alum is a lot less tolerant of repetitive flexing, and if hard welded tabs are resilient enough, no major problems should arise. One example IMO that is a problem is "overwelding" the tabs, welding itself causes possible future cracking issues, and the tab having some give instead of all streeses being directed to radiator has got to be a plus. That said, I weld tabs on mine, Angles welded on 3 of 4 sides only.
Re: Best way to mount an aftermarket aluminum radiator? [Re: jcc] #1492194
09/01/13 12:42 PM
09/01/13 12:42 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I did mine with a bracket on top like this. The bottom has 2 similar brackets on each side under the tanks, The brackets are lined with foam insulation. It's been like this for many years...works good
Re: Best way to mount an aftermarket aluminum radiator? [Re: Dcuda69] #1492195
09/01/13 12:57 PM
09/01/13 12:57 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Looks good....am going the same route, 22 inch 3 core alum radiator to replace current low budget 19 in a 22 core support, adding electric fan&external trans cooler.
