New Toy has Arrived - 69 Coronet 440 #1491970
08/28/13 11:49 AM
08/28/13 11:49 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
My new car has arrived from Texas. I am not well educated in the B-bodies, so I will need lots of help with this learning what are the common problems and what to do.
What I got was a 69 Coronet 440 in Q5 with a white vinyl top, black interior, 318/904 w/ A/C. Body is very clean with minor dings rust bubbles. Some things that aren't working include
Heat
A/C
Wipers
Back up lights
and it seems to be draining the battery as it sits idle.
Is it common for the heat/AC switch to go? I can't get some of the buttons to work/push in. The fan also seems to run even when the heat/AC is turned off.
The wipers are the two speed, so I need to do some investigation as to the problem.
The front bench looks nice, but the seat is VERY tired and you feel like you fall in when you sit on it. Any tips on how to get it back up to par?
Pics coming soon!
I'm looking to have some fun with this one - drop in a bigger engine, clean it up and beat on it a bit.
This is the first time since I was 17 that I didn't have an E-body of some variety in the garage!
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: New Toy has Arrived - 69 Coronet 440 [Re: Erik] #1491971
08/28/13 01:03 PM
08/28/13 01:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , it's a plastic switch that routes vacuum to move the air doors , it gets brittle and breaks .
Re: New Toy has Arrived - 69 Coronet 440 [Re: Erik] #1491972
08/28/13 03:47 PM
08/28/13 03:47 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I've got a 4 door version of that car. I loved it the way it was. The 318 and auto just can't be beat, it last forever and drives like a dream. The only thing I would change is better brakes.
Re: New Toy has Arrived - 69 Coronet 440 [Re: 71birdJ68] #1491973
08/28/13 05:52 PM
08/28/13 05:52 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
Original Paint? pictures please.....
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: New Toy has Arrived - 69 Coronet 440 [Re: Q5_Ed] #1491974
08/28/13 06:50 PM
08/28/13 06:50 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Well the yellow is original. It had a green vinyl top and green interior. The ex set the inside on fire by accident.Its all numbers matching, unleaded gas killed it. Last time I drove it was in the middle 90s.If I ever get the Road Runner done, I'd like to get it up and going again. Those ole B bodies just can't be beat.
Re: New Toy has Arrived - 69 Coronet 440 [Re: 71birdJ68] #1491975
08/28/13 06:51 PM
08/28/13 06:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
two
Re: New Toy has Arrived - 69 Coronet 440 [Re: Erik] #1491976
08/28/13 06:51 PM
08/28/13 06:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Let us see your's, I love 69s.
Re: New Toy has Arrived - 69 Coronet 440 [Re: 71birdJ68] #1491977
08/28/13 10:05 PM
08/28/13 10:05 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Pics:
Re: New Toy has Arrived - 69 Coronet 440 [Re: 71birdJ68] #1491978
08/28/13 10:08 PM
08/28/13 10:08 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
under construction
Re: New Toy has Arrived - 69 Coronet 440 [Re: Erik] #1491979
08/28/13 11:00 PM
08/28/13 11:00 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Beautiful car, enjoy it as it is.
Re: New Toy has Arrived - 69 Coronet 440 [Re: Erik] #1491980
08/30/13 10:43 PM
08/30/13 10:43 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
nice score.
Re: New Toy has Arrived - 69 Coronet 440 [Re: Golden-Arm] #1491981
08/30/13 10:46 PM
08/30/13 10:46 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
NICE!
Re: New Toy has Arrived - 69 Coronet 440 [Re: Erik] #1491982
09/01/13 09:00 PM
09/01/13 09:00 PM
Cold Spring, NY
1970GTX Offline
1970GTX  Offline
Cold Spring, NY
The heat/AC switch was used up to the mid 80's they are available at the dealer/eBay
wipers, make sure the is a ground strap going to the motor and mounting bolts.
seat, they might of recovered it and didn't add foam. You'll have to remove the cover and ad some 3" thick foam from Michael's craft store or some place similar.
back up lights, make sure they are well grounded, fuse? bulbs?
As long as it charges when you rev it, it should be good.
Re: New Toy has Arrived - 69 Coronet 440 [Re: 1970GTX] #1491983
09/07/13 10:30 PM
09/07/13 10:30 PM
Appleton, Wisconsin
rtmike Offline
rtmike  Offline
Appleton, Wisconsin
Great car. I love 68-69 coronets (and 70s too just not as much). I would drive that thing like crazy and never look back.
Its not primer its perma gray.
