engine won't fire #1491809
08/27/13 09:26 PM
08/27/13 09:26 PM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
Car is 67 Dart with 273. Engine was idling then quit. Found loose positive coil wire but overtightened nut and broke lug. Replaced with new coil. Wire from distributor to pos side of coil and wire from harness to neg side. No start. Engine turns over. Coil wire from dist. cap to coil seems tight. Battery is weak so I jumped it. Engine turned over as it should but no start. I have fuel-carb sqirters are working with new fuel pump that ran engine a few days ago. Can someone give me a step by step plan of action from here? I have a meter but really only know how to test continuity with it. I am dumb when it comes to elecrical and I am guessing it is some kind of electrical problem since it has fuel. Any help will be much appreciated. Thanks.
Re: engine won't fire [Re: 69fish] #1491810
08/27/13 09:31 PM
08/27/13 09:31 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Pull the plugs and either dry them or best to replace them. I bet your flooded out, try holding the carb wide open while you crank the sh!t out it or replace the spark plugs.
Connect a timing light on any spark plug wire and crank it. Does the light flash? If so I bet the plugs are junk.'
Good luck.
Re: engine won't fire [Re: Challenger 1] #1491811
08/27/13 09:43 PM
08/27/13 09:43 PM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
I held the the carb wide open while attempting to crank it but no go. I have flooded it before and that always worked up until now. Found my timing light and it did flash as engine cranked so I guess that means I have spark from the dist. to the plugs. Will try the plugs next. Probably overthinking this because I panic at thought of electical problems. Thanks.
Re: engine won't fire [Re: 69fish] #1491812
08/27/13 10:43 PM
08/27/13 10:43 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: engine won't fire [Re: Challenger 1] #1491813
08/27/13 10:46 PM
08/27/13 10:46 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
Wire from distributor goes to coil negative post and harness wire goes to coil positive post.
Re: engine won't fire [Re: Bumbalawski] #1491814
08/27/13 11:15 PM
08/27/13 11:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Coils hooked up backwards.
Re: engine won't fire [Re: Bumbalawski] #1491815
08/28/13 01:43 AM
08/28/13 01:43 AM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
X3
Re: engine won't fire [Re: MrFoFody] #1491816
08/28/13 02:42 AM
08/28/13 02:42 AM
Uranus
strokerchall Offline
Uranus
Is there power to the posi side of coil? Turn the key on and check with a test light. I bought a new coil once and it was hooped!
