COOLING TUBES IN DEEP TRANS PAN #1491431
08/27/13 12:41 AM
08/27/13 12:41 AM
Uranus
strokerchall Offline OP
Uranus
I picked up a 727 racing trans rated for 600hp,it has an extra deep pan and cooling tubes going through it,I'm going to look for a brand name in morn.The shop said you'll never see them anywhere... quite a cool idea
Re: COOLING TUBES IN DEEP TRANS PAN [Re: strokerchall] #1491432
08/27/13 12:47 AM
08/27/13 12:47 AM
Kirkland, Washington
Pacnorthcuda Offline
Mopar performance used to sell those, they were common. As I recall, a cool (pun intended) design but it meant the oil pickup could not reach deep into the pan and therefore poor circulation of fluid.
But others that ran them, will know for sure.
Re: COOLING TUBES IN DEEP TRANS PAN [Re: strokerchall] #1491433
08/27/13 12:49 AM
08/27/13 12:49 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Guess he doesn't get out much.
http://www.amazon.com/Derale-14210-Trans...;keywords=14210
Re: COOLING TUBES IN DEEP TRANS PAN [Re: Pacnorthcuda] #1491434
08/27/13 01:08 AM
08/27/13 01:08 AM
Uranus
Uranus
so what's the deal?
is air suppose to travel through them as you travel?
I hooked up a trans cooler aswell,this guy came highly reccommended from 2 shops.
Re: COOLING TUBES IN DEEP TRANS PAN [Re: strokerchall] #1491435
08/27/13 01:22 AM
08/27/13 01:22 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
so what's the deal?
Yes. I'm not sure enough air moves through those 1/4" diameter tubes to transfer much heat, though.
Re: COOLING TUBES IN DEEP TRANS PAN [Re: strokerchall] #1491436
08/27/13 01:39 AM
08/27/13 01:39 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
not sure how the air gets through them, the ones i've seen had the holes going from side to side. (if the holes went front to back, they could get plugged with debris) in theory, the surfaces of the tubes expose the trans fluid to a larger surface for heat exchanging. a good trans cooler placed after the radiator cooling tank should work well enough by itself. the pan is deeper, but as mentioned above, you don't get to pickup from the bottom of the pan. you do get a slightly larger fluid capacity though.
Re: COOLING TUBES IN DEEP TRANS PAN [Re: Golden-Arm] #1491437
08/27/13 09:13 AM
08/27/13 09:13 AM
scratchnfotraction Offline
brand name Derail maybe?(spelling?) they have a lot of stuff like that.
I have seen the tubes either way depending on the trans.
we ran them on the turbo400 pontiac trans,turbo350 chebby trans mostly.
they say right on the sales pitch not recomended for 4x4 use due to clogging.
IMHO, I would think one would keep them flushed out when running them on dirt roads/off road. I know I did.
Re: COOLING TUBES IN DEEP TRANS PAN [Re: strokerchall] #1491438
08/27/13 01:55 PM
08/27/13 01:55 PM
Frederick, MD
71charger Online content
71charger  Online Content
Frederick, MD
At my house, if you left the car sit for more than a week, the mud wasps would have all those tubes plugged up.
