First outing with the 410 pump gas motor #1491351
08/26/13 10:19 PM
08/26/13 10:19 PM
ont,canada
mopartuner Offline OP
ont,canada
Went to the strip with my 410 ci Eddy head,10.5 to 1 pump gas,solid flat tappet motor and ran a 11.07 @ 121 and by the end of the weekend ran a 10.96 @ 122 lifting at the finish line.Best et was the 10.96 best 60 was 1.59 and the mph was 123.77Motor felt strong but was probably held back a little by the 750 carb.My 850 needs some work before I am going to try it.The 60 ft times were not the greatest but the slicks I was using were probably 4 years old and I think my old superstock springs are starting to weaken.I hadent raced with a pro tree in 7 years but I cut some good lights and we had a good time and drove it on the trailer.A great weekend.
410 pump gas solis flat tappet cam 10.95 so far
Re: First outing with the 410 pump gas motor [Re: mopartuner] #1491352
08/26/13 11:07 PM
08/26/13 11:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice numbers on your first outing. Ron
Re: First outing with the 410 pump gas motor [Re: mopartuner] #1491353
08/26/13 11:08 PM
08/26/13 11:08 PM
Toronto
mshred Online content
mshred  Online Content
Toronto
Car ran awesome for the first time out Bob! Im sure with tuning you'll go .80's no problem! Good to finally meet ya and see the car in person!
Let me know when your heading up again
Re: First outing with the 410 pump gas motor [Re: mopartuner] #1491354
08/26/13 11:35 PM
08/26/13 11:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
nice times. Sounds like a rock solid combo.
Re: First outing with the 410 pump gas motor [Re: J_BODY] #1491355
08/26/13 11:43 PM
08/26/13 11:43 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Nice first outing! Now, tell us more:
1) Trans/Converter?
2) Car weight?
3) Rear gear?
4) Cam specs?
5) Heads??
6) Intake
7) Headers? Muffs???
Whew! That's all I think.
That is if you don't mind sharing...
Re: First outing with the 410 pump gas motor [Re: mopartuner] #1491356
08/27/13 01:07 AM
08/27/13 01:07 AM
Az
Crizila Offline
Crizila  Offline
Az
Awesome! The 850 will definitely help. Making good power though with the 750.
Fastest 300
Re: First outing with the 410 pump gas motor [Re: Crizila] #1491357
08/27/13 02:05 AM
08/27/13 02:05 AM
sweden
sshemi Offline
sshemi  Offline
sweden
My 408 gained nothing going from 750 carb to 950.
Re: First outing with the 410 pump gas motor [Re: cudadoug] #1491358
08/27/13 05:55 AM
08/27/13 05:55 AM
ont,canada
ont,canada
The car is a 65 barracuda 3150 lbs 40 over 360 w/4" crank.The heads are home ported and assembled Eddys with all Crower locks,ret,springs,ect.The cam is a custom from Crower 602/624 262/274 @ .050 on a 108cl installed at 104 deg.This is a flat tappet solid cam.Intake is a Victor,these runs are with mufflers.Car is weekly street driven.Trans is a 904 w/4400 conv(9.5")/low 1st, footbrake,8-3/4 rear w/410 gear and a 9x28 slick.Tim at FHO did the machine work and helped with parts and me and my friend Cris(I don't know if he wants his name on here)Chime in,we did assembly and the rest of the parts.These guys are the best,thanks.
Re: First outing with the 410 pump gas motor [Re: mshred] #1491359
08/27/13 06:01 AM
08/27/13 06:01 AM
ont,canada
ont,canada
Mopar Day?
Re: First outing with the 410 pump gas motor [Re: mopartuner] #1491360
08/27/13 09:30 AM
08/27/13 09:30 AM
sweden
sshemi Offline
sshemi  Offline
sweden
What was the 1/8 specs?
Re: First outing with the 410 pump gas motor [Re: sshemi] #1491361
08/27/13 10:17 AM
08/27/13 10:17 AM
Az
Crizila Offline
Crizila  Offline
Az
I shoulda known.
Fastest 300
Re: First outing with the 410 pump gas motor [Re: mopartuner] #1491362
08/27/13 10:32 AM
08/27/13 10:32 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Cool I plan on being at TMP mopar day too!
Re: First outing with the 410 pump gas motor [Re: sshemi] #1491363
08/27/13 12:13 PM
08/27/13 12:13 PM
AndyF Offline
AndyF  Offline
Most 950 carbs are actually 750's so there wouldn't be a difference.
Re: First outing with the 410 pump gas motor [Re: Dodgem] #1491364
08/27/13 12:15 PM
08/27/13 12:15 PM
NC
HMcCandless_Jr Offline
NC
That car should 60 foot 1.48 or so, if you pick up a tenth in 60 you will see two tenths at the finish line. You think I'm crazy but brush your tires with WD 40, yes I said that, if you don't believe me get an old tire, wash it with good, then put WD 40 on it, it will be as sticky as ever. You can save old slicks like this to get you by. After you get the car working right then start tuning the motor, to tune a motor when the chassis is off is wasting time.
Re: First outing with the 410 pump gas motor [Re: AndyF] #1491365
08/27/13 03:41 PM
08/27/13 03:41 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I was told it should flow 840cfm.
Mine should flow a little mote than that since it hava hand ported venturis.
Re: First outing with the 410 pump gas motor [Re: HMcCandless_Jr] #1491366
08/27/13 03:43 PM
08/27/13 03:43 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Is that a guarantied rule that you gain 2 tenth at the line when going one tenth quicker in the 60?
Sorry to highjack...
Re: First outing with the 410 pump gas motor [Re: sshemi] #1491367
08/27/13 04:26 PM
08/27/13 04:26 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
What size headers?
I just had Stephen Duarity expertly mod a set of 1 7/8" TTI's to fit in the Rocky and couldn't believe the difference even off idle and part throttle compared to the too small 1 5/8" that were on the 414. Can't wait for a day off to go
Re: First outing with the 410 pump gas motor [Re: Streetwize] #1491368
08/27/13 05:42 PM
08/27/13 05:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The 1.59 sixty is a little weak. If you pick your 60 up you will be faster. As for the 850 helping I dont know how much but I can tell you we tried an 800 and an anular 830 on my sons 406 (.030 over 400) Dart and it ran the best with the 750 DP on it. Good luck and nice going. Ron
Re: First outing with the 410 pump gas motor [Re: 383man] #1491369
08/27/13 09:53 PM
08/27/13 09:53 PM
ont,canada
ont,canada
The car back in 04 would 60 ft 1.52 with a motor at the same power level.I have some work to do for sure.The headers are the 1-5/8 to 1-3/4 step TTI pipes,This motor is making the same amount of power(same mph)as my old motor but the old motor was a 12 to 1 with a solid roller in it.The old motor had to struggle to breath through 1-5/8 headers.These new headers are a big reason this motor works well.Now its time in the winter to do some suspension and tires and make some 10.60 runs in the spring.
Re: First outing with the 410 pump gas motor [Re: sshemi] #1491370
08/27/13 09:55 PM
08/27/13 09:55 PM
ont,canada
ont,canada
Ran 7.03 @99.55 mph
