Why are these carb parts green? #1490818
08/25/13 11:10 PM
08/25/13 11:10 PM
Jacksonville, Fl
426runner Offline OP
Jacksonville, Fl
I just went through my carbs 2 weeks ago. They were pretty nasty from basically sitting for several years with very little use. Started the motor up after the meticulous cleaning and the motor ran WONDERFULLY. Well, it has been sitting for 2 weeks. I pulled the carbs apart again to re-jet/re-rod the carbs (based on info from a Moparts thread) and what do I find... green tinted gas and this green residue on the jets and rod tips!
Is this due to ethanol in the gas?? These parts are from the rear carb. 2 weeks ago, as I was listening to the car idle so nicely, it ran out of gas... there was just a bit of gas at the bottom of the carb... I'm assuming that's why the residue is only at the tips.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Why are these carb parts green? [Re: 426runner] #1490819
08/25/13 11:44 PM
08/25/13 11:44 PM
it'd have to be the gas but I've ran gasahol (E10 ethanol) with no discoloration
Re: Why are these carb parts green? [Re: 426runner] #1490820
08/25/13 11:49 PM
08/25/13 11:49 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Wow! I doubt an additive would do that. Pump some into a jar and let it sit. Florida humidity can combine with ethanol and they will sink to the bottom of the tank. Look and see if the water seperates out. I wonder if they delivery driver checks for water where you bought last. They try to cut corners all the time.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Why are these carb parts green? [Re: Rug_Trucker] #1490821
08/26/13 12:50 PM
08/26/13 12:50 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
oxidization I would think, brass turns green when it corrodes. Ethanol does love to attracts moisture.....
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Why are these carb parts green? [Re: 426runner] #1490822
08/26/13 01:29 PM
08/26/13 01:29 PM
That's what was in the back of my mind that I couldn't put my finger on & that is moisture. ethanol absorbs it so it's everywhere in the mixture & it ain't always settled at the bottom seperately like what happens with regular gas & I'd think it'd sure take a high percentage of it to corrode the brass green in 2 weeks. Hopefully just as said a bad load of gas but I'm wondering what it did elsewhere. Holler how it turns out
Re: Why are these carb parts green? [Re: RapidRobert] #1490823
08/26/13 10:22 PM
08/26/13 10:22 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Some fuel additives will do that, I suggest trying Lucas products Lucas Fuel Additives, one of the few products on the market that were formulated for todays gasoline that often contains ethanol.
Re: Why are these carb parts green? [Re: ScottSmith_Harms] #1490824
08/26/13 10:36 PM
08/26/13 10:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Something copper or copper based is corroding in your system.
Don't be the exception.
Re: Why are these carb parts green? [Re: Supercuda] #1490825
08/27/13 12:21 AM
08/27/13 12:21 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Those parts are brass? and Brass is copper based.
Re: Why are these carb parts green? [Re: 426runner] #1490826
08/27/13 01:51 AM
08/27/13 01:51 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Do you have any copper "fuel line" in use?
Re: Why are these carb parts green? [Re: DAYCLONA] #1490827
08/27/13 09:41 AM
08/27/13 09:41 AM
Jacksonville, Fl
Jacksonville, Fl
No copper fuel lines but I will point out that the gas was old... maybe even knockin on a year. Also I had an additive recommended by a local performance shop. Could be the perfect storm of negatives... old gas, ethanol/moisture and additive. Since this motor seems to be sorted out and I'll actually be burning the gas in a reasonable amount of time, I am rethinking what combination of fuels to use. Motor is close to stock 10+:1. A friend with a similar setup uses 3:1, 93 pump gas and 101 leaded race fuel. What do you guys use?
Re: Why are these carb parts green? [Re: 426runner] #1490828
08/27/13 09:50 AM
08/27/13 09:50 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Most fuel additives/performance boosters were developed before ethanol was added to gasoline blends so accordingly, can sometimes cause issues. If using an additive with gas that has ethanol be sure they are compatible first.
Re: Why are these carb parts green? [Re: ScottSmith_Harms] #1490829
08/27/13 09:20 PM
08/27/13 09:20 PM
I've had excellent results with the Star Tron Starbrite fuel system teatment. Supposedly it is engineered to elminate phase separation due to the ethanol in the gas today.
Re: Why are these carb parts green? [Re: ] #1490830
08/27/13 11:09 PM
08/27/13 11:09 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I've replaced fuel tanks and the sending units in my '67 Satellite and '70 Swinger because of Ethanol damage.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Why are these carb parts green? [Re: Copper Dart] #1490831
08/27/13 11:18 PM
08/27/13 11:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
The Sta-Bil marine formula is said to work good and one bottle treats like 380 gal.
http://www.goldeagle.com/mobile/products/product01A7.aspx
Re: Why are these carb parts green? [Re: ademon] #1490832
08/28/13 01:45 PM
08/28/13 01:45 PM
Southern Maryland
klunick Online content
klunick  Online Content
Southern Maryland
Had same thing with a 2 1/2hp go cart motor that I had sitting down in the basement for about 10 years. When I pulled the carb apart, all the gas was green and stunk like no tomorrow. That green crap is hard to get off your hands too!!
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Why are these carb parts green? [Re: klunick] #1490833
08/28/13 02:23 PM
08/28/13 02:23 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
I was just watching a Roadkill episode last night and they ran across the same thing. They talk about it at the 13:10 mark.
http://www.youtube.com/watch?v=yGjMIjNkwhc
Re: Why are these carb parts green? [Re: vdriver] #1490834
08/28/13 04:43 PM
08/28/13 04:43 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Looks like ethanol might be the cause of the green mystery coating...I've seen the texaco additives turn parts red,and shell gas turns some parts yellow...Green was a new one to me also...I use Star tron in the motorhome for the winter slumber and I use sta-bil ethanol treatment with each tank in the classic cars so mabe that's why I have'nt run across the green death yet..
Re: Why are these carb parts green? [Re: screamindriver] #1490835
08/28/13 04:58 PM
08/28/13 04:58 PM
Jacksonville, Fl
Jacksonville, Fl
Rest assured I will be including a compatible additive to the gas from now on . Thanks for all the help!!
