Is this an Ebody K frame? #1490669
08/25/13 08:12 PM
08/25/13 08:12 PM
Blairsden, CA
Triggerfish Offline OP
Blairsden, CA
I looked at pics of Mopar K frames to ID this one & closest it comes
to is an E body K frame, but is still a little different. Anyone know
what its from?
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490670
08/25/13 08:55 PM
08/25/13 08:55 PM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
I would doubt it due to the fact that it has the sway bar mount holes in the 69 and earlier location on the front lip of the k-frame
Re: Is this an Ebody K frame? [Re: Kilrbee] #1490671
08/25/13 09:24 PM
08/25/13 09:24 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
1968 or earlier because the idler arm mount has only one bracket....most likely a b-body k frame....it appears to be in very good condition
Re: Is this an Ebody K frame? [Re: LYNCHROAD69.5] #1490672
08/25/13 10:32 PM
08/25/13 10:32 PM
Blairsden, CA
Blairsden, CA
Do you think it could be a 65 B body K frame? I looked at Shumacher's
K frame tech page & it doesn't resemble any of the frames he shows. I
just bought a 64 big block Belvedere & want to move the motor back a
little with a later B body K frame & was hoping this one might work.
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490673
08/25/13 11:07 PM
08/25/13 11:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It is a 67 K frame at the latest because of the idler mount .
Re: Is this an Ebody K frame? [Re: JohnRR] #1490674
08/25/13 11:20 PM
08/25/13 11:20 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Have a pic of the other side?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Is this an Ebody K frame? [Re: moparmarks] #1490675
08/26/13 12:30 AM
08/26/13 12:30 AM
Blairsden, CA
Blairsden, CA
Here's the underside & I'll post a side pic
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490676
08/26/13 12:31 AM
08/26/13 12:31 AM
Blairsden, CA
Blairsden, CA
Side view
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490677
08/26/13 01:06 AM
08/26/13 01:06 AM
moparmarks Offline
moparmarks  Offline
Looks like a 66/7B frame
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Is this an Ebody K frame? [Re: moparmarks] #1490678
08/26/13 10:16 AM
08/26/13 10:16 AM
Blairsden, CA
Blairsden, CA
Thanks for the info & maybe I can use it for the 64 Belvedere.
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490679
08/26/13 03:03 PM
08/26/13 03:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you use a '66-later K-member in an early B it will set the engine back 1 5/8".
Re: Is this an Ebody K frame? [Re: John_Kunkel] #1490680
08/26/13 04:36 PM
08/26/13 04:36 PM
Blairsden, CA
Blairsden, CA
That's what I've heard, but is that really enough to make a difference
in the way the car will handle? Also think I'll have some clearance
issues with the 4 spd hump & the 440 heads clearing the firewall?
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490681
08/27/13 04:15 PM
08/27/13 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The main advantages of the setback is fan/radiator clearance, being able to use later oil pans and headers. Head clearance isn't a problem but the hump might need some massaging with a BFH.
Re: Is this an Ebody K frame? [Re: John_Kunkel] #1490682
08/27/13 04:24 PM
08/27/13 04:24 PM
Blairsden, CA
Blairsden, CA
Thanks John & will a crossram intake be a problem with the motor
set back 1 5/8"?
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490683
08/28/13 02:54 PM
08/28/13 02:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I don't think the crossram will fit with the setback, the passenger side plenum hits the cowl box.
Re: Is this an Ebody K frame? [Re: John_Kunkel] #1490684
08/29/13 10:32 AM
08/29/13 10:32 AM
Blairsden, CA
Blairsden, CA
Thanks & I figured as much. There's some info in the tech section that
talks about K frame issues as well. When I get the car & hopefully find
the fendertag or get info from Chrysler Historical, maybe it'll be
a street wedge car & that's how I'll build it. Don't think there will
be firewall clearance issues with a single 4bbl, but know there will
be fitment & mod issues with the 4 speed if I swap K frames. I wonder
if moving the motor 2"back is worth the hassle??
Re: Is this an Ebody K frame? [Re: JohnRR] #1490685
08/29/13 04:10 PM
08/29/13 04:10 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i agree...
Re: Is this an Ebody K frame? [Re: ph23vo] #1490686
08/29/13 09:09 PM
08/29/13 09:09 PM
Blairsden, CA
Blairsden, CA
i agree...
Thanks & was hoping it was 68 or later, so I may just have it blasted & see if its nice enough to sell.
Re: Is this an Ebody K frame? [Re: Triggerfish] #1490687
08/31/13 09:59 AM
08/31/13 09:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i agree...
You could make it use the 68 up idler by welding a tab above the idler .
