Re: Is this an Ebody K frame?
[Re: Triggerfish]
#1490673
08/25/13 11:07 PM
08/25/13 11:07 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
Do you think it could be a 65 B body K frame? I looked at Shumacher's K frame tech page & it doesn't resemble any of the frames he shows. I just bought a 64 big block Belvedere & want to move the motor back a little with a later B body K frame & was hoping this one might work.
It is a 67 K frame at the latest because of the idler mount .
[Re: moparmarks]
#1490678
08/26/13 10:16 AM
08/26/13 10:16 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Looks like a 66/7B frame
Thanks for the info & maybe I can use it for the 64 Belvedere.
[Re: Triggerfish]
#1490679
08/26/13 03:03 PM
08/26/13 03:03 PM
Posts: 25,910 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you use a '66-later K-member in an early B it will set the engine back 1 5/8".
[Re: John_Kunkel]
#1490680
08/26/13 04:36 PM
08/26/13 04:36 PM
Triggerfish
Blairsden, CA
That's what I've heard, but is that really enough to make a difference in the way the car will handle? Also think I'll have some clearance issues with the 4 spd hump & the 440 heads clearing the firewall?
[Re: Triggerfish]
#1490681
08/27/13 04:15 PM
08/27/13 04:15 PM
John_Kunkel
Rio Linda, CA
The main advantages of the setback is fan/radiator clearance, being able to use later oil pans and headers. Head clearance isn't a problem but the hump might need some massaging with a BFH.
[Re: John_Kunkel]
#1490682
08/27/13 04:24 PM
08/27/13 04:24 PM
Triggerfish
Blairsden, CA
Thanks John & will a crossram intake be a problem with the motor set back 1 5/8"?
[Re: Triggerfish]
#1490683
08/28/13 02:54 PM
08/28/13 02:54 PM
John_Kunkel
Rio Linda, CA
I don't think the crossram will fit with the setback, the passenger side plenum hits the cowl box.
[Re: John_Kunkel]
#1490684
08/29/13 10:32 AM
08/29/13 10:32 AM
Triggerfish
Blairsden, CA
Thanks & I figured as much. There's some info in the tech section that talks about K frame issues as well. When I get the car & hopefully find the fendertag or get info from Chrysler Historical, maybe it'll be a street wedge car & that's how I'll build it. Don't think there will be firewall clearance issues with a single 4bbl, but know there will be fitment & mod issues with the 4 speed if I swap K frames. I wonder if moving the motor 2"back is worth the hassle??
[Re: JohnRR]
#1490685
08/29/13 04:10 PM
08/29/13 04:10 PM
Posts: 14,471 renton, Washington
ph23vo
renton, Washington
i agree...
[Re: ph23vo]
#1490686
08/29/13 09:09 PM
08/29/13 09:09 PM
Triggerfish
Blairsden, CA
i agree...
Thanks & was hoping it was 68 or later, so I may just have it blasted & see if its nice enough to sell.
[Re: Triggerfish]
#1490687
08/31/13 09:59 AM
08/31/13 09:59 AM
JohnRR
U.S.S.A.
i agree...
You could make it use the 68 up idler by welding a tab above the idler .
