'99 Voyager Windows No Worky #1489453
08/23/13 03:15 PM
08/23/13 03:15 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
The windows on my friends Voyager won't go up and down. He pulled the driver's door panel and changed the switches out with a JY part.
Fuses are all good. Is there a module somewhere to change out or check?
Gracias!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: '99 Voyager Windows No Worky [Re: Rug_Trucker] #1489454
08/23/13 03:22 PM
08/23/13 03:22 PM
Santa Ana, CA
DustyChicken Offline
Santa Ana, CA
Check the wiring between the door and the body. The wires for the windows are thick gauge and breakage is not uncommon.
Re: '99 Voyager Windows No Worky [Re: DustyChicken] #1489455
08/23/13 03:40 PM
08/23/13 03:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check for a relay under the hood.
Re: '99 Voyager Windows No Worky [Re: stumpy] #1489456
08/23/13 03:58 PM
08/23/13 03:58 PM
Big black rectangular box of fuses and relays didn't have anything labeled "windows." I am guessing that is where it should be?
Re: '99 Voyager Windows No Worky [Re: Rug_Trucker] #1489457
08/23/13 04:17 PM
08/23/13 04:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it has a relay that will be where it is.
Re: '99 Voyager Windows No Worky [Re: stumpy] #1489458
08/23/13 05:03 PM
08/23/13 05:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I know this is about fan relay but it shows where all the relays and fuses are. http://www.fixya.com/cars/t10454016-replace_fan_relay_99_plymouth
Re: '99 Voyager Windows No Worky [Re: stumpy] #1489459
08/23/13 06:39 PM
08/23/13 06:39 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check for power and ground at the switch.But as said Ill bet its the wires in the door.Repaired a ton at work.You must look real close.as Ive had some that look good till you check close then you see the break.Rocky
Chrysler Firepower
Re: '99 Voyager Windows No Worky [Re: therocks] #1489460
08/23/13 07:53 PM
08/23/13 07:53 PM
South Dakota
hotairballoonpilot Offline
South Dakota
I test them this way.
Jump box or battery charger take small wire from each side of the power source. Unhook the wire from the motor. Touch red to one spade black one to other spade. If no movement switch sides. If window goes down or up either way motor is good. If not its motor. If it does then check wires that go through post into door. I test that by having someone hold switch in either down or up depending on where window is at. with key in on position btw. While they are doing that I grab the wires and move them up or down and around. Usually if there are broken wires in that group you will get some action in the window. If not there then switch or relays but usually it's one of those.
Contact Me about AMD Prices
Re: '99 Voyager Windows No Worky [Re: hotairballoonpilot] #1489461
08/23/13 08:02 PM
08/23/13 08:02 PM
Great! Thanks! He had to leave. Looking at the bends in the harness to the door?!!! It may very well be the problem!
Thanks again, MOPARTS Rocks!
