'99 Voyager Windows No Worky
#1489453
08/23/13 03:15 PM
08/23/13 03:15 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
The windows on my friends Voyager won't go up and down. He pulled the driver's door panel and changed the switches out with a JY part.
Fuses are all good. Is there a module somewhere to change out or check? Gracias!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: '99 Voyager Windows No Worky
[Re: stumpy]
#1489459
08/23/13 06:39 PM
08/23/13 06:39 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Check for power and ground at the switch.But as said Ill bet its the wires in the door.Repaired a ton at work.You must look real close.as Ive had some that look good till you check close then you see the break.Rocky
Chrysler Firepower
[Re: therocks]
#1489460
08/23/13 07:53 PM
08/23/13 07:53 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
I test them this way.
Jump box or battery charger take small wire from each side of the power source. Unhook the wire from the motor. Touch red to one spade black one to other spade. If no movement switch sides. If window goes down or up either way motor is good. If not its motor. If it does then check wires that go through post into door. I test that by having someone hold switch in either down or up depending on where window is at. with key in on position btw. While they are doing that I grab the wires and move them up or down and around. Usually if there are broken wires in that group you will get some action in the window. If not there then switch or relays but usually it's one of those.
Contact Me about AMD Prices
