Fuel Return: What Size Hole? #1489162
08/22/13 09:26 PM
08/22/13 09:26 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am making a fuel return block and my current return barb fitting has a 3/16" ID. I am assuming that this is too large and I am planning on adding a fitting to the inside and just drilling the required hole size.
My old filter with a return line has a 1/16" hole for the vapor return and the psi held steady at 6psi at idle. Should I drill it at 1/16" or just let the return line have the 3/16" ID to keep the fuel moving?
Note: This is for an electric fuel pump.
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489163
08/22/13 09:29 PM
08/22/13 09:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Fuel return block ? Do you have a regulator ? you should and it will only return what doesn't get used.
Re: Fuel Return: What Size Hole? [Re: JohnRR] #1489164
08/22/13 09:51 PM
08/22/13 09:51 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
The pump is a street pump and it only puts out 7psi max.
I am pretty sure that I have read some threads of members making their own return blocks (T's) and I am wanting to know what size restriction works. So far I have found threads showing .060-.080" in size.
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489165
08/22/13 10:34 PM
08/22/13 10:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use a vapor separator with a mechanical pump and reduce the return orifice size to .035".
Re: Fuel Return: What Size Hole? [Re: lewtot184] #1489166
08/22/13 10:44 PM
08/22/13 10:44 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
How did you decide on the .035?
Does anyone know the thread size of a Holley/QF main jet? Is it 1/4-32?
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489167
08/22/13 10:57 PM
08/22/13 10:57 PM
If the setup is the same except your using the restriction you want to drill into the fuel block instead of the 1/16" vapor return filter orifice restriction then yes I'd drill the restriction in the fuel block to the same 1/16" & see if you still have 6psi you want at the carb inlet then adj the orifice from 1/16" (if need be)
Re: Fuel Return: What Size Hole? [Re: RapidRobert] #1489168
08/22/13 11:03 PM
08/22/13 11:03 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
With the NAPA vapor return/filter with the .060" return orifice gave me 6+psi at the carb. If I make the orifice smaller, would the pressure at the carb go up until the fuel pump is maxed out?
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489169
08/22/13 11:06 PM
08/22/13 11:06 PM
yes, not sure how much tho
Re: Fuel Return: What Size Hole? [Re: RapidRobert] #1489170
08/22/13 11:13 PM
08/22/13 11:13 PM
IN
ahy Offline
ahy  Offline
IN
With no regulator, "rule of thumb" the orifice should be .050". Too big and fuel pressure drops. Too small, there is not enough re-circulation to keep things cool and free of vapor.
Re: Fuel Return: What Size Hole? [Re: ahy] #1489171
08/23/13 07:46 AM
08/23/13 07:46 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Good info, thanks!
I have modified my return line barb fitting for a plug. I will drill the plug with the appropriate hole size before I install it.
If I can find a 1/4-32 tap, I may tap down farther into the barb fitting for a jet. Then I can test different size holes to see if the fuel pressure changes.
Thanks again to everyone.
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489172
08/23/13 07:53 AM
08/23/13 07:53 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i arrived at .035" thru some flow and pressure tests. what kind of pump are you using that will maintain 6psi with a .060" orifice?
Re: Fuel Return: What Size Hole? [Re: lewtot184] #1489173
08/23/13 08:08 AM
08/23/13 08:08 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am using a Holley Red pump. My fuel pressure at idle always shows 6+ (apx 6.2-6.5) at idle with the NAPA vapor/fuel filter that has a .060 return hole.
I have a .052" drill bit that I might start with. I have plenty of plugs to drill out if I can't find a tap.
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489174
08/23/13 10:41 AM
08/23/13 10:41 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
a constant flow pump will probably react differently than a pulse. if .060" is working good for you now then stick with it.
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489175
08/24/13 11:19 AM
08/24/13 11:19 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I decided to start a little smaller on the hole size with a .052" return hole. I now have a solid 6 3/4psi at idle!
Going from the .060" to the .052" moved the idle psi from 6 1/4 to 6 3/4! I am keeping it there since the pump is rated at 7psi.
Before I installed the return block, I was running water through it to clean it out before I installed it on the car. I was surprised how much fluid can come through such a small hole. This should still allow good circulation back to the tank.
Thanks allot for the replies!
Re: Fuel Return: What Size Hole? [Re: YO7_A66] #1489176
08/24/13 11:51 AM
08/24/13 11:51 AM
Success! did you drill/tap the big end of the barb fitting for an NPT plug then drill/tap the NPT plug 1/4-32 for the holley jet?
Re: Fuel Return: What Size Hole? [Re: RapidRobert] #1489177
08/24/13 12:07 PM
08/24/13 12:07 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I only tapped the barb fitting for the NPT plug, then drilled the plug to .052. I had trouble locating the 1/4-32 tap, so I just drilled the plug.
Thanks for your help.
