Fuel Return: What Size Hole?
#1489162
08/22/13 09:26 PM
08/22/13 09:26 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I am making a fuel return block and my current return barb fitting has a 3/16" ID. I am assuming that this is too large and I am planning on adding a fitting to the inside and just drilling the required hole size. My old filter with a return line has a 1/16" hole for the vapor return and the psi held steady at 6psi at idle. Should I drill it at 1/16" or just let the return line have the 3/16" ID to keep the fuel moving?
Note: This is for an electric fuel pump. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Fuel Return: What Size Hole?
[Re: JohnRR]
#1489164
08/22/13 09:51 PM
08/22/13 09:51 PM
YO7_A66
Indiana
The pump is a street pump and it only puts out 7psi max. I am pretty sure that I have read some threads of members making their own return blocks (T's) and I am wanting to know what size restriction works. So far I have found threads showing .060-.080" in size. Thanks
[Re: lewtot184]
#1489166
08/22/13 10:44 PM
08/22/13 10:44 PM
YO7_A66
Indiana
How did you decide on the .035?
Does anyone know the thread size of a Holley/QF main jet? Is it 1/4-32?
[Re: RapidRobert]
#1489168
08/22/13 11:03 PM
08/22/13 11:03 PM
YO7_A66
Indiana
With the NAPA vapor return/filter with the .060" return orifice gave me 6+psi at the carb. If I make the orifice smaller, would the pressure at the carb go up until the fuel pump is maxed out? Thanks
[Re: YO7_A66]
#1489169
08/22/13 11:06 PM
08/22/13 11:06 PM
RapidRobert
yes, not sure how much tho
[Re: ahy]
#1489171
08/23/13 07:46 AM
08/23/13 07:46 AM
YO7_A66
Indiana
Good info, thanks!
I have modified my return line barb fitting for a plug. I will drill the plug with the appropriate hole size before I install it. If I can find a 1/4-32 tap, I may tap down farther into the barb fitting for a jet. Then I can test different size holes to see if the fuel pressure changes. Thanks again to everyone.
[Re: YO7_A66]
#1489172
08/23/13 07:53 AM
08/23/13 07:53 AM
Posts: 3,916 usa
lewtot184
usa
i arrived at .035" thru some flow and pressure tests. what kind of pump are you using that will maintain 6psi with a .060" orifice?
[Re: lewtot184]
#1489173
08/23/13 08:08 AM
08/23/13 08:08 AM
YO7_A66
Indiana
I am using a Holley Red pump. My fuel pressure at idle always shows 6+ (apx 6.2-6.5) at idle with the NAPA vapor/fuel filter that has a .060 return hole.
I have a .052" drill bit that I might start with. I have plenty of plugs to drill out if I can't find a tap. Thanks
[Re: YO7_A66]
#1489175
08/24/13 11:19 AM
08/24/13 11:19 AM
YO7_A66
Indiana
I decided to start a little smaller on the hole size with a .052" return hole. I now have a solid 6 3/4psi at idle! Going from the .060" to the .052" moved the idle psi from 6 1/4 to 6 3/4! I am keeping it there since the pump is rated at 7psi. Before I installed the return block, I was running water through it to clean it out before I installed it on the car. I was surprised how much fluid can come through such a small hole. This should still allow good circulation back to the tank. Thanks allot for the replies!
[Re: YO7_A66]
#1489176
08/24/13 11:51 AM
08/24/13 11:51 AM
RapidRobert
Success! did you drill/tap the big end of the barb fitting for an NPT plug then drill/tap the NPT plug 1/4-32 for the holley jet?
[Re: RapidRobert]
#1489177
08/24/13 12:07 PM
08/24/13 12:07 PM
YO7_A66
Indiana
I only tapped the barb fitting for the NPT plug, then drilled the plug to .052. I had trouble locating the 1/4-32 tap, so I just drilled the plug. Thanks for your help.
