Re: Ill Fitting Door Glass on 69 GTX
[Re: jlatessa]
#1488449
08/21/13 06:14 PM
08/21/13 06:14 PM
Posts: 1,317 Ohio
jlatessa
Ohio
Took my straight-edge and laid it along bottom-inside surface and there was virtually no arc to the glass at that point.
Hope that helps, I can see where a curved piece would cause interference.
Joe
P.S. My glass is out of the car so unrestrained.
[Re: frank]
#1488454
08/22/13 09:08 PM
08/22/13 09:08 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
The glass in my car is not flat. It bows outboard
I have 2 70's with original glass if you would like me to check.
[Re: CaptainGTX]
#1488456
08/24/13 03:33 PM
08/24/13 03:33 PM
gdonovan
Oakdale CT
I'm sure 68-70 glass is the same, but if you'd mind checking your 70s I'd appreciate it.
Very flat, no curve noted.
Just a thought- From the factory it would be impossible to be curved both vertical and horizontal, how would you roll the glass up and down without a huge opening?
Like trying to roll a shallow bowl up and down.
[Re: HotRodRailroader]
#1488458
08/27/13 04:46 PM
08/27/13 04:46 PM
Funny I should come across this when I was checking the entire moparts sections instead of just parousing the resto section like I usually do just to catch up on stuff I've missed. I recently saw this thread over on forbbodiesonly a couple days ago and the pics there seem to show that it is flat. Even going as far as having an original laid over the top of the repro's they sell. I'll try to copy the pics and post here for everyone to see.
[Re: ]
#1488459
08/27/13 04:47 PM
08/27/13 04:47 PM
[Re: ]
#1488460
08/27/13 04:47 PM
08/27/13 04:47 PM
