Need advice on supercharged 340 build
#1488333
08/21/13 01:17 PM
08/21/13 01:17 PM
Posts: 52 Pennsylvania
73bluebird
Pennsylvania
Approximately 10 years ago I had a stock 1973 340 engine completely rebuilt by my local speed shop. I bought the complete original motor for in my ’73 Road Runner, but after finding that it had sand in the oil pan from the previous owner not properly sealing the ports when he sand blasted it to clean it up, we realized that a complete rebuild would be necessary before attempting to fire up the motor. At the time we wanted a budget build and the speed shop happened to have a used B&M supercharger laying around that we ultimately decided to incorporate into the build. The total cost back then was around $4500 and through dyno testing they proved the motor had 371 hp and 402 lb./ft torque (see details of this build listed below). I was really hoping to hit the 425 hp mark so that I could have the satisfaction of knowing that I had a small block motor cranking out around the same amount of hp that was advertised with the stock 426 hemi engines (I know the 426’s were probably advertised lower than what they actually put out), but that didn’t happen.
Now several years later I’m almost ready to put the motor back in the car, which will primarily be used for street use (kind of a pro touring vibe to the restoration I guess). I located an original B&M blower intake manifold because I wanted a nice clean manifold (my custom manifold worked, but wasn’t really show quality) for appearance purposes. I could only buy the manifold in a package deal, and what the seller told me was a 144 supercharger ended up being a 162 supercharger much to my delight. So starts the turmoil in my engine plans. I want to upgrade to the larger blower and I still have the 425 hp goal in my mind. Other upgrades that I have to go along with the engine include TTI ceramic coated headers, Rev-N-Nator electronic ignition, Firecore distributor, coil and wire set, and a Powerjection throttle body fuel injection setup. The engine will be matted to a Tremec TKO-600 5-speed transmission and an 8 ¾ Sure-grip rear end (gear to be determined, leaning towards 3.73 or 3.91). The car also has subframe connectors, an adjustable rear pinion snubber and HD big block leaf springs to handle the increased torque.
Through researching the topic I came across a Mopar Muscle magazine from 1992 featuring the Dick Landy Inc. supercharger engine build. In the article, dLi is claiming 450 hp from a 144 supercharger on a 340 engine with mild porting to stock heads and an upgraded cam, while they claim 500 hp from their high-engery supercharger and moderate porting of the heads. With this in mind I’m starting to wonder why my engine is built nearly the same, minus the porting work, but is producing way less hp on the dyno. I realize that dynos can be calibrated differently, but at 80 hp difference between their engine and mine I’m a bit concerned.
I’m looking for some suggestions on what to do to give my engine a little more power (425-500 hp range) without completely rebuilding it once again. Simply porting the factory heads, upgrading to aluminum heads, and even scrapping everything to buy a long block stroker motor have all crossed my mind. The only consistent thing I know is that I want a 340 block and the B&M forced induction setup that can be run on pump gas (or 92 Super if necessary), everything else could be subject to change. What I need is some input from Mopar engine gurus who know more about this sort of thing than I do. I’d like to get the car on the road next year, so what I’m looking for advice on the best way to liven up the engine without going completely crazy and dumping a ton of money into it. I could really use some guidance so I could quit stressing and pick a direction to take this engine build. Sorry for the long post, and thanks for taking the time to read.
Current Engine Specs. Engine Displacement: 345 ci Peak Horsepower: 371 at 5400 rpm Peak Torque: 402 lb./ft at 3900 rpm Bore: 4.070 Stroke: 3.310 Compression Ratio: 8.27:1 Crankshaft: Stock, cast-iron Main Bearings: Sealed Power, 4923MA10, Bi-metal Connecting Rods: Stock forged Rod Side Clearance: 0.010-0.140 Rod Bearings: Sealed Power, 2130CP10, Tri-metal Pistons: Speed Pro, L2316F30, forged Rings: Sealed Power, E286K30, Iron Moly Ring End Gap Clearance: 0.026/0.026 Cylinder Heads: Stock 587, machined for larger intake valve Combustion Chamber Size: 68cc Intake Valve Size: 2.02 Exhaust Valve Size: 1.60 Valve Springs: COMP Cams 995-16, 1.700 installed height Rocker Arms: Mopar Performance stock type Pushrods: Stock Camshaft: COMP Cams 20-223-3 Hydraulic Int./Exh. Duration at 0.050 Lift: 224/230 Int./Exh. Max Valve Lift: .477/.480 Intake Centerline: 106 Lobe Separation: 110 Timing Set: Stock Intake Manifold: Customized low profile single plane aluminum Edelbrock blower manifold Induction: B&M 144 Roots-type supercharger (2.08:1 drive ratio, approx. 7-8 lbs boost) Fuel Delivery: Demon 750 cfm blower carb Ignition: Mopar Performance Timing Specs: 33 degrees total Exhaust/Headers: Hooker Super Comp.
Re: Need advice on supercharged 340 build
[Re: 73bluebird]
#1488334
08/21/13 01:37 PM
08/21/13 01:37 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Was the original blower the smaller one when it was dyno tested? Peak HP is determined at certain RPM, change he amount of boost and the HP and RPM can and will change The key to making power on any motor is airflow, the more air and fuel the more power you get If I was you and the smaller blower was on the motor I wouldn't change anything on the motor until I ran the bigger blower BTW, I have dyno tested several roots blown pump gas motors, I have seen 100 HP gain by going from 12 % under driven at 7 lbs of boost going to 13 % over driven with 12 lbs of boost with race gas The bigger blower can be ran slower and make the same boost while forcing more volume through the motor at WOT which will make more power Slowing the blower down also results in cooler inlet temps, which is really important to help prevent detontaion. If your not going to use the bigger blower I would change the heads to a good set of new aluminum heads like the Edlebrock or Indybrocks with bigger ports and valves with the sme size combustion chambers as you have now, that will allow more air into the motor as well as help keep the combustion temps in control in the cylinders IHTHs
[Re: Cab_Burge]
#1488337
08/21/13 01:52 PM
08/21/13 01:52 PM
73bluebird
Pennsylvania
Yes, the engine specs listed are the way the engine was built and tested, including the 144 supercharger. My thoughts on switching to the larger blower was that I could drive it slower and keep some of the temps down while producing the same boost as you explained. I have read and reread the B&M Supercharger Technical manual at least a dozen times, but unfortunately the engine builds and graphs they collected were non-Chrysler. That's what got me thinking more about head porting and cam selection, but I just don't have enough knowledge or experience with specific parts to be able to compare them to say another compatible part (ie. cams) or combination.
I considered porting my stock heads, but for roughly $1000 to get a stage III port job and gasket matching on the intake also I'm wondering if a better flowing (compared to the stock heads I have now) unported set of aluminum heads would be a better investment of my money. To complicate this even further, I've heard both positive and negative things about running aluminum heads with a supercharger.
[Re: 73bluebird]
#1488339
08/21/13 02:08 PM
08/21/13 02:08 PM
Cab_Burge
You should keep in mind that the stock block has a limit on how much power it can handle before failing, especially driving a crank driven supercharger I would put the bigger blower on it now and lower the drive ratio by around 3 to 5 %, try that and then, after looking very closely at all of the spark plugs , look at increasing the blower boost I would also install a manifold inlet temperature gauge(under the blowerr ) and not go nuts on WOT with inlet temps over 200 F I don't remember the exact HP and torque differences on testing with 130 F inlet temps. and 190 F, but it was measurable and detonation started at a lot lower RPM The last blown motor I dyno tested made peak power at 7300 RPM with 7 lbs of boost with 33 degrees total timing, we switch the pulleys and that motor made peak power at 6500 RPM with 25 degrees timing at 12 lbs of boost and it was starting to detonate I shuld have put the timing at 20 degrees total instead of starting at 25 degrees Lesson learned on testing We ran out of dyno time and the customer wasn't going to hook the power we made at 7 lbs, 927 HP at 7300 RPM with 860 ft lbs at 5500 RPM Be very careful on your tuning
[Re: Cab_Burge]
#1488340
08/21/13 02:26 PM
08/21/13 02:26 PM
73bluebird
Pennsylvania
Those dyno numbers are impressive! I am aware of and concerned about detonation, but don't really know how far I can push my engine until this would become a problem. Again, I've never built an engine myself and am trying to learn as I go here, so I appreciate your explanations. I definitely don't want to push my engine so far that there is a reliability issue or that it's teetering on the edge of self destructing. I'm thinking that I want to have my rev-limiter set to around 5500 rpm in order to prevent damage to the A/C compressor (rated for use up to 6000 rpm) and also to keep the blower speed within a safe range (they are not to exceed 12,000 rpm and at a 2.08:1 drive that is exceeded before 6000 rpm). I really plan to use the car for cruising and not racing, so I'm thinking that WOT runs would be limited and that the fifth gear .64 OD will help keep cruising RPMs down on the highway.
Thanks to all who have posted so far, I appreciate all of your comments and suggestions and will be exploring some of them in more depth.
[Re: 73bluebird]
#1488341
08/21/13 04:56 PM
08/21/13 04:56 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Well for what it's worth....
My dad has been running a supercharged stock block, stock crank, ported iron headed, 340" since '85. The motor is ~8:1 and had a cam very similar to yours in it for most of it's life (finally upgraded to a R3 block, and big solid cam in late 2000's).
At 3850lbs, the car had run a best of 11.60's@117mph with 12~13psi. Now this is with a V671 blower, not the B&M stuff, but you can see the potential and durability is there for what you're talking about.
I honestly would put it together with what you have. If you're unhappy with the results, you can always make changes later, but what you have isn't mismatched really at all. Might have to play around with the boost/timing to get the tune right, but it'll make over 400 with it's eyed closed once you get it right.
Bolt that big blower up and let it rip!
[Re: dizuster]
#1488342
08/21/13 08:22 PM
08/21/13 08:22 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
Id love to see pics of your setup. I have a NOS B&M 162 supercharger setup. But I need to build a shortblock for it one day...
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: 73bluebird]
#1488343
08/21/13 08:29 PM
08/21/13 08:29 PM
Posts: 4,213 New York
polyspheric
New York
Camshaft: COMP Cams 20-223-3 Hydraulic Int./Exh. Duration at 0.050 Lift: 268/280
That's a typo, right?
Boffin Emeritus
[Re: dizuster]
#1488344
08/21/13 11:13 PM
08/21/13 11:13 PM
Posts: 9,882 MI, usa
dvw
MI, usa
With the bigger cam (245@,050",540/560,110 LCA) 9" PTC, home ported 308 heads,4.30 gear its gone 11.01@123 at 3890lbs thru mufflers. Doug
[Re: 73bluebird]
#1488345
08/21/13 11:34 PM
08/21/13 11:34 PM
Cab_Burge
I should have clarified that motor was not a blown SB, it is a 496 C.I. 426 style Hemi with a Littlefield 10:71 and two Carb Shop 1050 Dominator blower carbs. Sorry for not being clear to start with BTW, I have built several N/A SB 340 NHRA stocker motors that made 430 HP over 12 yrs ago, more is possible now with the current technology and parts
[Re: polyspheric]
#1488346
08/22/13 12:51 AM
08/22/13 12:51 AM
73bluebird
Pennsylvania
Yes, Duration at 0.050 Lift should be 268/230
As far as head upgrades, I've been researching the Mopar LA Super Commando heads. They're a little pricey, but seem like they have about the best flow numbers for exhaust. If I were to buy the heads assembled (as advertised by Mopar), what other parts would I have to track down to make them work with my engine?
Here's a pic of the engine as it currently sits, still with the custom intake, 144 blower and Demon carb.
[Re: 73bluebird]
#1488347
08/22/13 01:09 AM
08/22/13 01:09 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
just bumpt the compression to 10 or so and ditch the blower and make the same power.
Seems pretty lame that motor only making 370/400 a mild N/A build can do that without trying. I think something big is wrong with the motor, cam timing, leakdown...
[Re: HotRodDave]
#1488348
08/22/13 01:12 AM
08/22/13 01:12 AM
HotRodDave
Kalispell Mt.
What manifold did you start with?
Ditch the Fram filter.
[Re: polyspheric]
#1488349
08/22/13 02:25 AM
08/22/13 02:25 AM
Posts: 660 River Falls, WI
urdustd
River Falls, WI
That cam has advertised duration of 268/280 Duration @0.050 is 224/230
A 10:1 N/A 340 with that cam and factory heads will make 375+HP. I know that blower isn't a real powerhouse but it should easily make over 400HP even at 8.25:1! I remember reading articles about DLi using that blower on low compression 400's to make 450 or so HP. I do not remember the cam they used though....
[Re: urdustd]
#1488350
08/22/13 12:39 PM
08/22/13 12:39 PM
Posts: 2,578 sweden
1Fast340
sweden
that cam will only make 375+ hp in a magazine fairytale written by the usual unicorns in a stockheaded 340 N/A
