Steering box PN for E-body???? #1488320
08/21/13 11:53 AM
08/21/13 11:53 AM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Will a power steering box with PN - G2267262 fit an e-body???
Jason
Re: Steering box PN for E-body???? [Re: CUDAJAS] #1488321
08/21/13 12:08 PM
08/21/13 12:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That looks like the CASTING number. That casting number is the early part of the 60's and would be found on a box probably up to 72 ???
What is the box out of ? Other than an obscure C body box all mopar rear wheel drive passenger car boxes have the same mounting bolt pattern from sometime in the early 60's all the way up to the last of the M body cop cars. The biggest change, I can think of, is the size of the output shaft and the pitman arm used, that change happened for the 73 model year.
Re: Steering box PN for E-body???? [Re: JohnRR] #1488322
08/21/13 12:14 PM
08/21/13 12:14 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
I am told its out of a 69 Coronet.
Jason
Re: Steering box PN for E-body???? [Re: CUDAJAS] #1488323
08/21/13 12:21 PM
08/21/13 12:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jason
It will bolt into your e body but you will need a pitman arm for a 70 or 71 cuda I ASSuME...
I don't know if E bodies changed like A bodies , but when I put a 73 up box in a 72 duster I had to change the center link and the idler arm to 73 up pieces because the stud on the new pitman arm pointed 180 from the 72 arm.
Also how USED is it??? It may not be any better than the box you are replacing ...
Re: Steering box PN for E-body???? [Re: JohnRR] #1488324
08/21/13 12:27 PM
08/21/13 12:27 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Jason
Thanks John,
I am looking to switch from manuual to power steering, so If it needs to be rebuilt, that is ok..it is a really good price even just for a core.
I have a new fast ratio pitman arm and ldler arm for my manual box that will fit the small sector power box.
Jason
