Re: Steering box PN for E-body????
[Re: CUDAJAS]
#1488323
08/21/13 12:21 PM
08/21/13 12:21 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I am told its out of a 69 Coronet.
Jason
It will bolt into your e body but you will need a pitman arm for a 70 or 71 cuda I ASSuME...
I don't know if E bodies changed like A bodies , but when I put a 73 up box in a 72 duster I had to change the center link and the idler arm to 73 up pieces because the stud on the new pitman arm pointed 180 from the 72 arm.
Also how USED is it??? It may not be any better than the box you are replacing ...
[Re: JohnRR]
#1488324
08/21/13 12:27 PM
08/21/13 12:27 PM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
Jason
Thanks John,
I am looking to switch from manuual to power steering, so If it needs to be rebuilt, that is ok..it is a really good price even just for a core.
I have a new fast ratio pitman arm and ldler arm for my manual box that will fit the small sector power box.
Jason
