Left vs Right Side Water Pump Housing..Differences?
#1487687
08/20/13 10:39 PM
08/20/13 10:39 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
What's the reasoning that the 440 trucks had a passenger side water pump housing?
I bought a radiator from Champion radiators which isn't going to work b/c they don't have one that has the inlet/outlet on both the passenger side that'll work and/or fit.
Im thinking that if I change water pump housings (I was going to change out the timing belt anyhow) and switch it over to the drivers side, I'll be able to get a champion aluminum radiator that'll fit/work.
Would there be a fitment issue with this? The truck is a 74 Ramcharger SE, with a 440 & Factory A/C if that matters.
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
Re: Left vs Right Side Water Pump Housing..Differences?
[Re: shanker]
#1487690
08/20/13 11:17 PM
08/20/13 11:17 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
You will also have to change out all your accessories as they differed on the early DS outlet housings ('72-earlier) versus the later ('73-'78) pass. side outlet housings. The A/C compressor moved and they used a different bracket for the PS setup.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: shanker]
#1487693
08/20/13 11:24 PM
08/20/13 11:24 PM
MoPar Jamie
Sarcoxie, MO, USA
Yeah gone through this all when I was working on a '70 Fury with a '78 motor. Fortunately the SB radiator in my '72 Fury is on the pass. side as I have a '75 440 motor going into it.
- MoPar Jamie
[Re: dogdays]
#1487696
08/21/13 12:17 PM
08/21/13 12:17 PM
shanker
Corpus Christi, TX
looks like I'll be going with this radiator: The bracket is listed as being 1" narrower than the OE so I should be able to make that work w/o too much hassle. CORE DIM� (H x W) - 16 1/4 X 26 OVERALL (H x W) - 22 5/8 x 29 HOSE FITTINGS - In 1 -1/2 - Out 1- 3/4 BRACKET SPECS - Horizontal - 27 1/2 Champion lists it as for B & E bodies with 5.7 & 6.1L Hemi's in them...
