power to manual steering adapter #1487621
08/20/13 07:38 PM
08/20/13 07:38 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
are there more than one option for this piece?
seems a little pricey?
thanks
Re: power to manual steering adapter [Re: mcat4321] #1487622
08/20/13 09:56 PM
08/20/13 09:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought this small 2" or so shaft from Mancini to make up the difference for the longer shaft needed for manual steering boxes. I believe it was about $115. Ron
Re: power to manual steering adapter [Re: 383man] #1487623
08/21/13 12:44 PM
08/21/13 12:44 PM
Western NY
19SuperBee70 Offline
Western NY
I extended the shaft, redrilled the holes for the plAstic pins and put new pins in. Works fine.
Re: power to manual steering adapter [Re: mcat4321] #1487624
08/21/13 01:11 PM
08/21/13 01:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yea it is getting pricy
http://chucker54.stores.yahoo.net/mamastad.html
go to the wrecking yard and check out 80's dodge vans.
others use these??
http://chucker54.stores.yahoo.net/flristcoad.html
Re: power to manual steering adapter [Re: Dodgem] #1487625
08/21/13 01:16 PM
08/21/13 01:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The K-member I just bought came with a manual box and the inner part of the steering column still attached. Will I be able to just remove the inner shaft from my existing steering column and slide in the one that's still attached?
Re: power to manual steering adapter [Re: burdar] #1487626
08/21/13 02:22 PM
08/21/13 02:22 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Yes. See if the shaft has been collapsed. If it has, extended where it should be and put a couple nylon pins in it.
Re: power to manual steering adapter [Re: mopowers] #1487627
08/21/13 02:35 PM
08/21/13 02:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The inner part of the collapsible tube has been pulled out. The outer half stayed with the car I assume.
Re: power to manual steering adapter [Re: burdar] #1487628
08/21/13 02:53 PM
08/21/13 02:53 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
So you only have the lower half of the shaft???
Re: power to manual steering adapter [Re: mopowers] #1487629
08/21/13 03:00 PM
08/21/13 03:00 PM
Alberta, Canada
K
krisiesmopes Offline
K
Alberta, Canada
Not sure if Chrysler has it anymore, it was 4037651, but about 2 bills last time I checked.
Re: power to manual steering adapter [Re: krisiesmopes] #1487630
08/21/13 03:17 PM
08/21/13 03:17 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yep, that was still attached to the steering box when I bought it. I was hoping it would slide right up into the upper half of my PS column.
