TTI X Pipe Assembly Length
#1487263
08/20/13 09:02 AM
08/20/13 09:02 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Those of you that are running this. Does the assembly extend to where the mufflers would attach at the rear floor board?
Since my springs are moved in and I am running the stock tank I don't have the space to get tail pipes out the back. So, I need to dump before the rear axle. It appears that the x pipe assemble plus a set of mufflers and turn downs should do the trick?
Running TTI headers as well.
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: TTI X Pipe Assembly Length
[Re: Locomotion]
#1487269
08/20/13 02:25 PM
08/20/13 02:25 PM
Crazy68Dart
Canton, Ohio
Thanks. So, the x-pipe takes it to the muffler attachment point for sure. I already have hangers off the seat belt bolts from the previous exhaust. That is what I needed to know. I am also concerned that I won't have space for turn downs, especially with the Dana 60 in the stock location (i.e not moved back) in a 68 Dart.
Would be great if I could get tail pipes out the back. There is a lot going on back there on a narrow A-body with the D60, stock tank, and moved in springs. Even if I could get the pipe over the rear end housing, that might help some without taking them the whole way to the bumper.
[Re: Locomotion]
#1487272
08/20/13 10:53 PM
08/20/13 10:53 PM
Crazy68Dart
Canton, Ohio
I really appreciate the help, guys. I just ordered the x pipe through Mancini. I'll see what I have to work with regarding some type of tail pipes. I just want to get the car back on the road, so I might live with turn downs for the time being.
[Re: Crazy68Dart]
#1487274
08/21/13 09:34 PM
08/21/13 09:34 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I have TTI headers on my '68 fastback cuda with a small block. I also use the TTI 2.5" x-pipe with flowmaster super44's that dump in front of the rear axle. plenty of room. I also use the TTI hangers that use the rear seat mounting bolts.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
